Page 36 of 150 1 2 … 34 35 36 37 38 … 149 150
Re: Wrench fest for Lloyd [Re: TOASTY] #1024018 07/26/11 07:05 PM
Lloyd Swartz Offline
I will check around here. What year Sports are talking? As far as SAS, you have a point. Now it would mean a likely cancellation of October for me, now that the X is gone. Might add a little cost with steering components, heavy duty axles, ect. If you guys are up for the work, I have nothing to loose. I just want to make sure it will handle well on those long drives to the Sierras.....
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024019 07/26/11 08:53 PM
TOASTY Offline OP
As long as the diff is 4.90 it will be the right one, the smaller axles have different ratios. Look for '00 on for the best chances of finding a AWD.
Re: Wrench fest for Lloyd [Re: TOASTY] #1024020 07/26/11 09:32 PM
TOASTY Offline OP
As for SAS, first we'd need to source an early Bronco or Jeep TJ front suspension on the cheap then you'd need to sell your RD110 to one of us who doesn't already have a locker. Then you'd need gears, locker (unless you sourced Rubicon D44) and Spindles to go Chevy 6 lug which will add a half inch to your WMS/WMS. These days you can make a D44 pretty stout with RCVs and stuff.
The other option is full custom axle, Trailgear has some good ones Rock Assult But then you're looking at getting a 3 link and custom suspension either from them or somebody local to us (I know some people).
So we can stick with the plan which we know is good or we could SAS with a factory setup from another truck if we can find one and that would be better or do the H-CORE thing and go unbreakable.
You could also do an SAS later trucks are cool like that <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Wrench fest for Lloyd [Re: TOASTY] #1024021 07/26/11 10:48 PM
wrenchwench Offline
I am going to suggest not biting off a SAS at this time.. you can always do it later if you want to but it seems smarter to focus on getting this thing working first, then do fancy stuff later.
Hey if you're going to relocate the truck to somewhere else, would it be wise to put the big tires on since they won't fit inside? I can do that so it's all ready to go, or whatever works for you guys.
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024022 07/26/11 11:15 PM
PA_JERO Offline
Sounds like a dare harry!
Its a double dare!
I like the way this is going, I think lloyd needs an SAS on this truck. If we are gonna do it, I say we go big or go home fellas! I think if the truck is gonna be built for punishment, we hold no limits!
Granted I am not the welder, so its not really up to me. But I have no problem lending my hand to this. And If we move it over to toasts house Its alot easier for me to get over there.
Ryan, how much do you want for all of that stuff you just posted. I REALLY need those items? I will also send you a PM.
Re: Wrench fest for Lloyd [Re: TOASTY] #1024023 07/26/11 11:17 PM
motero Offline
I would wait on the sas too. Having said that, there is a bronco with the needed parts here in Wittmann he would let them go cheap, they are very rusty though. I have a trailer too. To bad I am so far away. Keep up the good work.
<img src="/forums/images/graemlins/lol.gif" alt="" />
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Wrench fest for Lloyd [Re: TOASTY] #1024024 07/26/11 11:24 PM
motero Offline
If you go with the sport diff, can I call dibs on the one you take out, Mine is 4.6 gears and the carrier is messed up, meaning I cant get it to stop leaking out the drivers side.
Sorry, carry on...
01 montero limited
Re: Wrench fest for Lloyd [Re: motero] #1024025 07/26/11 11:43 PM
PA_JERO Offline
Sorry, carry on...
OH, I see the method behind your madness! You don't want the SAS swap to happen because you want a new carrier!!! J/K <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
I know the SAS is a bit of a battle but its not impossible. I think with a few extra hands toasty can pull if off better than most. Plus, we now know where the parts are. I don't mind going to pick them up. <img src="/forums/images/graemlins/smile.gif" alt="" />
Just Sayin!
Re: Wrench fest for Lloyd [Re: motero] #1024026 07/26/11 11:46 PM
Canyonero Offline
Valve spring compressor and spark plug air adapter showed up on my door step today. Ready on the tool front. Now I just got to put my engine back together, or at least the timing belt to relieve my cam tools of their current duty.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Wrench fest for Lloyd [Re: Canyonero] #1024027 07/26/11 11:50 PM
PA_JERO Offline
Sounds like we might be able to get that motor build going a bit earlier! YAY!
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.019s) Memory: 0.6521 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-11-03 17:44:15 UTC
