Page 46 of 150 1 2 … 44 45 46 47 48 … 149 150
Re: Wrench fest for Lloyd [Re: TOASTY] #1024118 10/12/11 07:43 AM
Canyonero Offline
Me and PAJ put the band back together for tonight.
Valve stem seals = DONE! <img src="/forums/images/graemlins/kewl.gif" alt="" />
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Wrench fest for Lloyd [Re: Canyonero] #1024119 10/12/11 05:34 PM
TOASTY Offline OP
Wow, i need to hurry up <img src="/forums/images/graemlins/smile.gif" alt="" />
Me and Paj have to go buy some steel for our trucks, so i?ll pick up the last little bit i need for Lloyds frame and bumper.
Lloyd, your winch seems too tall to mount to the top of the frame rails so i think it will have to go in between like the rest of us. Unless you want me to just go ahead and mount the plate on top and you can relocate your oil cooler when you install the winch. The interference is maybe an inch, I don't want to just weld the plate and have you deal with that later unless you're prepared and willing to make it work. I'm not going to relocate the cooler because i'm not a 100% it needs to be moved, I just know that my mock up winch i made is a box (sized to the winch measurements you gave me) and it hits the cooler but the winch will be a different shape and might clear because of that.
Make sense? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Wrench fest for Lloyd [Re: TOASTY] #1024120 10/13/11 03:47 AM
PA_JERO Offline
The goal is to have this engine totally back together by the end of this weekend.
Toast, lets get some more of that fab work done on lloyds truck so we can move it over here. We need to get it done so when lloyd comes to pick it up we can take him wheeling to give it a run. <img src="/forums/images/graemlins/kewl.gif" alt="" />
And just so everyone knows, It takes about 3 hours to do the valve stem seals on one head and then about 20 min to do the other.
Re: Wrench fest for Lloyd [Re: PA_JERO] #1024121 10/19/11 07:15 PM
TOASTY Offline OP
Bumper is all together, not welded yet but it is permanent. Hope you like it Lloyd because I don't have the steel for another rework and i'm ready to get onto the next thing. <img src="/forums/images/graemlins/smile.gif" alt="" /> I need to work on the front frame now.
The fit is nice and low profile with a great approach angle, I'll keep a look out for tube for hoops. I might also make a second fairlead mount and just throw it in the truck in case you need to mount your fairlead higher. Your winch has got to be huge larger than a MileMarker 12000, The box in the picture represents your winch. You can see the possible winch/oil cooler interference, It's only about an inch but if your winch is anything like the others we have (Ramsey, MileMarker, Warn, Shittybuilt) it will be narrower at the top and might just clear. I'll leave that up to you.
[Linked Image] [Linked Image] [Linked Image] [Linked Image]
Re: Wrench fest for Lloyd [Re: TOASTY] #1024122 10/19/11 07:32 PM
Man, that truck looks like it needs wheel spacers...
Couldn't resist.
Re: Wrench fest for Lloyd [Re: JohnnyBfromPeoria] #1024123 10/20/11 12:44 AM
Lloyd Swartz Offline
It is definately an original Skunk Works Creation! Looks better here then on text messaging. It is way more low profile then I thought from the phone pictures. Looks like winch will be easy to get to as well. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Spacers will be high on the priority list.....
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024124 10/20/11 12:51 AM
It looks "rockin'" in person, too. Toasty did a great job.
Re: Wrench fest for Lloyd [Re: JohnnyBfromPeoria] #1024125 10/20/11 02:27 AM
The flat bumper is nice as well, for when I am being a [censored] and want 10 people on my bumper to keep from flipping over <img src="/forums/images/graemlins/smile.gif" alt="" /> Very creative bumper, definately an amazing job! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024126 10/20/11 08:24 AM
TOASTY Offline OP
It's much better in person, I had a crappy shadow this morning. The fit is just about perfect and will be perfect when it's bolted on, but your body is not square to the frame i found out. It should settle into it's correct place once it?s driven and wheeled, if not we'll have to loosen the body bolts and give it a push.
The approach angle is awesome, in front of the tire the bottom is over 35" from the ground and maybe 7" away from the body! The front frame section is turning out pretty cool too, basically upside down of what mine is on the '99. So about 2" more clearance than i have in the center (not counting the difference with the 37's).
Hope to get the frame done tomorrow and i'll take more pictures.
Re: Wrench fest for Lloyd [Re: TOASTY] #1024127 10/21/11 03:49 PM
PA_JERO Offline
Good job yo! When we gonna do you want to get that truck over to my garage. Just a thought, will that truck even fit in my garage?
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.036s Queries: 16 (0.033s) Memory: 0.6541 MB (Peak: 0.7817 MB) Data Comp: Off Server Time: 2026-11-13 05:43:49 UTC
