Page 48 of 150 1 2 … 46 47 48 49 50 … 149 150
The wild world of yaks [Re: TOASTY] #1024138 11/21/11 10:45 PM
wrenchwench Offline
We're moving the truck next weekend to Kevin's to get the engine installed. Pat said once the engine is in he can install the T-case (can't do it now because there's nothing to really hold the transmission other than it's mount).
Hell yeah! I am pretty useless with this stuff but do you still need the oil pan from the old engine? Or other parts? Or the hoist? I am back in town for a short while, probably.
Re: The wild world of yaks [Re: wrenchwench] #1024139 11/22/11 03:26 AM
Lloyd Swartz Offline
The t/case won't work with out the engine? <img src="/forums/images/graemlins/nana.gif" alt="" /> Hubs should be on the way shortly...
Re: The wild world of yaks [Re: Lloyd Swartz] #1024140 11/22/11 04:18 AM
Canyonero Offline
Oh, it will work, but you'll have to crank it by hand. <img src="/forums/images/graemlins/lol.gif" alt="" />
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: The wild world of yaks [Re: Canyonero] #1024141 11/22/11 06:48 PM
TOASTY Offline OP
We still need the oil pan and probably some other stuff from your garage WW.
Re: The wild world of yaks [Re: TOASTY] #1024142 11/22/11 07:00 PM
After the last time I took my trailer hitch off, I noticed that at least one more of my bolts won't hold in the threads. That makes at least two that aren't holding, so I'm reluctant to want to try to pull a trailer to get the rest of the stuff out of WW's garage.
Should I drill out the holes and re-tap them to a larger size? If I do that, I'll probably have to drill larger holes in the hitch, too, and I don't have a drill press to accomplish that.
Or, does anyone nave an idea of how to do it differently? Can a plate with sufficient thickness be welded on top of the one already there, drilled and tapped for the stock sized bolts?
Re: The wild world of yaks [Re: JohnnyBfromPeoria] #1024143 11/22/11 07:24 PM
wrenchwench Offline
Man... sorry to hear about the threads - hopefully you can come up with a suitably safe fix! Meanwhile, I have a hitch if you have a trailer... call or txt me to organize if we need to move things around.
Re: The wild world of yaks [Re: JohnnyBfromPeoria] #1024144 11/22/11 10:56 PM
monte3 Offline
JB, what you could do is drill out the mount slightly, and try to insert a grade 8 bolt from the backside of the mount. Then use a lockwasher and nylon locking nut to attach the hitch. Food for thought...
Speaking of food, Happy Thanksgiving! <img src="/forums/images/graemlins/cheers.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: The wild world of yaks [Re: monte3] #1024145 11/23/11 01:22 AM
Have a great Thanksgiving, and make sure before you start cooking, the Trash Can Turkey is thawed! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: The wild world of yaks [Re: monte3] #1024146 11/23/11 03:31 PM
No way. There isn't even enough room to get a nut in there, let alone a bolt. If I could even get a nut between the hitch mounting plate and the tube part of the frame I'd be O.K., but that's not possible, as far as I can tell.
No cooking on my part, Lloyd, but that sounds like a valid tip.
Canadian Kilted Yaksmen [Re: JohnnyBfromPeoria] #1024147 11/23/11 05:49 PM
TOASTY Offline OP
Enjoy your Thanksgivings, Yaksmen!
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.026s Queries: 15 (0.022s) Memory: 0.6552 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-11-02 04:01:48 UTC
