Page 55 of 150 1 2 … 53 54 55 56 57 … 149 150
Re: Progress! [Re: Lloyd Swartz] #1024208 03/30/12 03:50 PM
PA_JERO Offline
might be easier to send them my way. I'll PM you my address.
Saturday afternoon Pat is gonna come over and Were gonna put the T-case in....YAAAAAY!
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Progress! [Re: PA_JERO] #1024209 03/30/12 06:18 PM
TOASTY Offline OP
So does that mean you won't be helping me move the diesel to the ground for a test run?
Re: Progress! [Re: TOASTY] #1024210 03/30/12 11:27 PM
PA_JERO Offline
I still plan on helping you...dude!
Dust...
Wind....
Dude...
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Progress! [Re: PA_JERO] #1024211 03/31/12 04:25 AM
Lloyd Swartz Offline
Let me know how it bolts up.......I will look at 2" spacers tomorrow to order.
Re: Progress! [Re: PA_JERO] #1024212 04/01/12 05:38 AM
DR1665 Offline
Dust...
Wind....
Dude...
That is so crates.
If I weren't balls deep in getting this Galant back together and down the road, I'd be up to lend a hand. Gotta get familiar with how these things come apart and go back together sooner than later, methinks.
Brian DR1665 | GBXM | Gearheads United.
89 Raider SWB [rock] | 91 Galant VR4 [roller]
Re: Progress! [Re: DR1665] #1024213 04/01/12 02:43 PM
Someone want to measure what the center bore needs to be on those wheel spacers? Measure across the hub rim to rim...
Re: Progress! [Re: Lloyd Swartz] #1024214 04/01/12 05:57 PM
The center bore needs to be 108mm. Most spacers I've seen have smaller bores. You can usually tell just by looking if it's the right size if the hole for the lug nut almost touches the center bore hole. There is usually no more than ~1/8" (I'd say 1/16" is what I recall seeing) between the holes. See the spacer pic I posted from trailgear.com above.
HTH <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Progress! [Re: Lloyd Swartz] #1024215 04/01/12 05:57 PM
4.25", Lloyd.
Re: Progress! [Re: JohnnyBfromPeoria] #1024216 04/01/12 06:03 PM
4.25", Lloyd.
Yup or 4.251969" if you wanna be more exact. 108mm is the actual spec IIRC. The difference could mean having to grind them down for clearance.
Re: Progress! [Re: off-roader] #1024217 04/01/12 08:03 PM
PA_JERO Offline
I have some pictures but I don't think I'm even gonna bother posting them due to it being from a crappy blackberry camera. You can hardly tell whats going on in the picture. LT and I put the new tail housing on and also put the rubicon case in and It fits right up in there. Couple things we'll have to do it fab up a new tranny mount and get some hardware. Pat I think has a few other things that we need to do but the test fit is done and lengths have been measured for driveshafts.
Motor is pretty much all put together except the Radiator, starter and air box, oh and torque converter bolts but pretty minor stuff.
lloyd that ARB fridge works great!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.028s Queries: 15 (0.024s) Memory: 0.6523 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-11-03 12:22:51 UTC
