Page 56 of 150 1 2 … 54 55 56 57 58 … 149 150
Re: Progress! [Re: PA_JERO] #1024218 04/02/12 03:53 PM
Lloyd Swartz Offline
Ok, I will make a call on spacers. Let me know when you get a quote on some shafts.
Those Fridges are amazing. I never had a problem with that unit. The lining is a mess because a fuel can spilled while in Baja. I have to say, I know the numbers dont betray it, but the newer Fridges seem to suck down more juice for some reason <img src="/forums/images/graemlins/confused.gif" alt="" />
Size [Re: Lloyd Swartz] #1024219 04/02/12 04:02 PM
Ok, those spacers on trail gear are 4 1/8". I am assuming all the others on the market will be the same, set up for Toyotas....
Re: Size [Re: Lloyd Swartz] #1024220 04/02/12 04:13 PM
Ok, I see lots of references to 1.25" and 1.5" spacers. All over ebay for 140.00 a set. Must have been a recent liquidation of these suckers. How about it, 1.5" enough?
Re: Size [Re: Lloyd Swartz] #1024221 04/03/12 11:24 PM
PA_JERO Offline
1.5" should be enough and give it a good stance. We should check to make sure the spacers don't require a special lug nut or anything, or at least come with the hardware to adapt the spacer to the stock spindle. If not I have a kick <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> hardware store down the road from here.
Also, Whats the situation with the 4:90's. Are we gonna be putting these in if we find some? I know Pat and I found a set that would work for the front but the Rear was a different story. I will need to double check all of this to find out if the yard still has them.
Re: Size [Re: PA_JERO] #1024222 04/04/12 02:38 AM
Measure the offset and backspacing on Lloyd's wheels. That'll tell you if the spacers will be sufficient.
Re: Size [Re: JohnnyBfromPeoria] #1024223 04/04/12 03:41 AM
Those are Montero specific spacers, so they should be ok. Just let me know if 1.5" should work, and I will order. Lets do the gears, I cannot see leaving the last major piece un-finished....
Re: Size [Re: Lloyd Swartz] #1024224 04/04/12 04:35 AM
TOASTY Offline OP
Pretty sure those wheels are 5" backspace, I run 3.5" backspace wheels and i slightly rub the pitman arm but my tires are 13.5's
Re: Size [Re: TOASTY] #1024225 04/04/12 04:48 AM
Sounds like 1.5" should do it then...
Re: Size [Re: Lloyd Swartz] #1024226 04/04/12 06:01 AM
PA_JERO Offline
ha ha, not to sound ignorant but I don't know how to measure for backspacing otherwise I would. To me an 1.5" spacer means its gonna push the wheels 1.5" out from there origanal point of contact so if that is basically all we are looking at that should be plenty. Its only an 8" wheel so it should be fine. If anything its gonna be better than running an 8" wheel with more backspacing to just the wheel. Did that make any sense to anyone else <img src="/forums/images/graemlins/confused.gif" alt="" />. I say roll with the 1.5" spacers. And if they are montero specific thats the way to go. I think it should be plenty.
Engine bay is full and all loose ends are pretty much tied up as of tonight. I just need to throw in the starter is pretty much it, should have been in today but I got side tracked with other crap so... it will be in tomorrow.
While I installed the radiator I went ahead and lowered it. The Shroud went on perfectly and got all the radiator hoses clamped down tight. BTW, is it possible the lower part of the fan shroud that clips on to the bottom at WW's house still. I looked everywhere for it but couldn't find it anywhere. If not its cool I will snag one at the yards on saturday if I find one. Either way that won't stop us from giving it a start.
When ever your ready lloyd I would like to get some fluids to poor into this thing so we can get ready to fire it up. Basically just some Coolant, oil, and we should probably replace the oil filter seeing how its been on there for about 7 years. <img src="/forums/images/graemlins/lol.gif" alt="" />. Won't obviously be ready to drive but it will fire up and idle so I have an idea on how it sounds, leaks, sensors, different things to make sure theres no hickups. This way if theres anything that we have to dive into we can do it while we are waiting on drive shafts. Which I beleive pat should be figuring out the driveshaft thing this week. <img src="/forums/images/graemlins/kewl.gif" alt="" />
So Lloyd, Where you gonna let me 4 wheel your truck for a shake down run??? <img src="/forums/images/graemlins/smile.gif" alt="" /> I'll be gentle...kinda <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Size [Re: PA_JERO] #1024227 04/04/12 08:25 PM
Sounds great, I will order the spacers, and then get some money to you guys for fluids and driveshafts when we find out what they will cost.
Shake down run <img src="/forums/images/graemlins/shame.gif" alt="" /> I know your idea of a shake down run <img src="/forums/images/graemlins/zombie.gif" alt="" /> Hopefully we can do that like on a Saturday when I come out. Then I can plan some tests over the summer. Who knows, maybe we can still pull off a Sierra Challenge in late August? Of course the Sierras is more like a shake apart test.... <img src="/forums/images/graemlins/ignore.gif" alt="" />
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.025s Queries: 15 (0.022s) Memory: 0.6567 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-11-02 14:18:34 UTC
