Page 90 of 150 1 2 88 89 90 91 92 149 150
Re: St. Patrick's day WRENCH-A-Roo [Re: Lloyd Swartz] #1024558 03/18/13 04:30 AM
TOASTY Offline OP
goodish, we learned the hard way that a CAD sport axle does not fit in a montero. You have what i think is the first CAD eliminator on a montero sport axle, we welded the CAD in the LOCK position, cut off the stub, cut off the detent then plated over it and welded it shut. This was all to clear the oil pan becaust the sport has it's actuator on the top side. luckily we had the port-a-band or this would have been more of a nightmare. The front is almost completely together, the aisin dials are soaking in WD-40 because they are gummed up bad and hard to turn. We were able to safely remove all but one bearing between both diffs so that was a victory, the one on the rear diaphram side needed to be pulled off by the outer race to keep from damaging the diaphram that is no longer available. Good progress rough day <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: St. Patrick's day WRENCH-A-Roo [Re: TOASTY] #1024559 03/18/13 02:37 PM
Lloyd Swartz Offline
Wow, the non-Cad set up turned out to be a pain! Thought it had been done before....
Re: St. Patrick's day WRENCH-A-Roo [Re: Lloyd Swartz] #1024560 03/18/13 03:23 PM
lordtrunks Offline
we were unable to find a non cad unit local with a 4.90 for a good price so we had to pickup a cad diff BUT the sport cad axle has the actuator on top of the axle into the diff vers the montero cad set which has it on the rear, this difference makes for cleanance issues so we had to make the diff into a non cad diff with help from the porta band and a welder. <img src="/forums/images/graemlins/kewl.gif" alt="" /> so front end is pretty much back together now passenger side brake caliper has some issue with the threads kevin is gonna give you a call.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: St. Patrick's day WRENCH-A-Roo [Re: lordtrunks] #1024561 03/18/13 08:16 PM
PA_JERO Offline
This is the part number of the bearing we were not able to salvage.
MR196898
The dealer can no longer order this part, discontinued. Otherwise I was gonna have you call the local dealer for us so it would only take a few days for us to get. That obviously wont work now. If you want the genuine part then were gonna have to order through Mitsubishiparts.net again. Which is no biggie just gonna take a little longer to get here.
Re: St. Patrick's day WRENCH-A-Roo [Re: PA_JERO] #1024562 03/18/13 08:46 PM
Canyonero Offline
Looked for a Timken cross referenced bearing, but no luck.
BUT, I do find a Dodge bearing that MAY be an equivalent bearing, same size and description in ASA as well. Part number is: MR453231. Online search shows $30 for the part. Might want to call a few Dodge dealers in the area to see if they might have the part in stock, and if they can confirm compatibility.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: St. Patrick's day WRENCH-A-Roo [Re: Canyonero] #1024563 03/18/13 08:52 PM
ClayTK Offline
Crazy how parts are becoming non-existent for our trucks.
1998 Mitsubishi Montero
2" Body lift
35" Cooper tires
Parrot Asteroid Smart w/ factory AMP
Cobra 29 LX CB Radio w/ Firestik MK-DM18R rooftop mount
Aisin Manual hubs
Grote 36 LED, TractorPlus (Wired to factory fog light switch)
Re: St. Patrick's day WRENCH-A-Roo [Re: ClayTK] #1024564 03/18/13 11:51 PM
lordtrunks Offline
they are still there you just have to know how to look for them clay. <img src="/forums/images/graemlins/smile.gif" alt="" />
jay mr453231 should work its the newest version of that bearing from what i can see in the ASA program and not a dodge bearing very mitsu its used on the blister fender montero's with the 3.5 should be a match all specs match up 90.00x23.00-55.00
Re: St. Patrick's day WRENCH-A-Roo [Re: lordtrunks] #1024565 03/19/13 12:40 AM
TOASTY Offline OP
That's what i ordered when i did mine but it is a blister fender so booyaa!
Re: St. Patrick's day WRENCH-A-Roo [Re: TOASTY] #1024566 03/19/13 03:53 PM
PA_JERO Offline
$85 bucks for this bearing. I'll get it ordered but it may have to wait a week or so.
Re: St. Patrick's day WRENCH-A-Roo [Re: PA_JERO] #1024567 03/20/13 03:00 PM
ClayTK Offline
$85 for a bearing!?
2" Body lift
35" Cooper tires
Aisin Manual hubs
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.019s) Memory: 0.6552 MB (Peak: 0.7640 MB) Data Comp: Off Server Time: 2026-06-07 04:49:01 UTC
