Page 95 of 150 1 2 … 93 94 95 96 97 … 149 150
Re: Bearing is In [Re: ryany] #1024608 04/16/13 04:16 AM
Lloyd Swartz Offline
For that kind of money I think I will go with out...Of course for 20.00 if someone stumbled across some at a yard that would be worth it.
Re: Bearing is In [Re: Lloyd Swartz] #1024609 04/18/13 12:00 AM
PA_JERO Offline
We'll see what we can find. If we run across a set I may grab them, so long as there not seized into the spindle like yours were.
Re: Bearing is In [Re: PA_JERO] #1024610 04/18/13 04:23 AM
Yep, exactly my thoughts. The only reason I am really thinking about this is we are likely moving up to Colorado in about 1.5 years, and even with big tires ABS is nice on Ice.
Re: Bearing is In [Re: Lloyd Swartz] #1024611 04/18/13 04:36 AM
TOASTY Offline OP
You're gonna leave New Mexico and not move to AZ? <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Bearing is In [Re: PA_JERO] #1024612 04/18/13 03:19 PM
Usually, the sensors come right out. The tougher part is unsnaking the wiring. Both fronts have a harness that seems to be ten feet long.
Re: Bearing is In [Re: TOASTY] #1024613 04/19/13 03:53 AM
Too big a whimp for those summers! We should have some great wheeling in our own back yard up there. Will be slightly further from AZ, and the Southern Sierras...But closer to a lot more great wheeling, closer to Utah and closer to the Northern Sierras....
Re: Bearing is In [Re: Lloyd Swartz] #1024614 04/21/13 05:11 AM
PA_JERO Offline
<img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Bearing is In [Re: PA_JERO] #1024615 04/21/13 06:00 PM
TOASTY Offline OP
Why not northern Az like Flag or Prescott, then you could do all the Az 4wheeling and still be closer to the sierras and Utah. Think about it...
Re: Bearing is In [Re: TOASTY] #1024616 04/21/13 07:32 PM
ClayTK Offline
Paj and myself just hit the junk yard yesterday to pull a rear axle from a Sport and it had the ABS sensors on it. I would assume the sensors are the same front to rear except for how long the wiring is to the plug.
1998 Mitsubishi Montero
2" Body lift
35" Cooper tires
Parrot Asteroid Smart w/ factory AMP
Cobra 29 LX CB Radio w/ Firestik MK-DM18R rooftop mount
Aisin Manual hubs
Grote 36 LED, TractorPlus (Wired to factory fog light switch)
Re: Bearing is In [Re: ClayTK] #1024617 04/21/13 08:13 PM
Excellent. Moving is also about being near family, and more importamt a WELL paying job for her tha has the potential to grow.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.032s Queries: 15 (0.028s) Memory: 0.6527 MB (Peak: 0.7583 MB) Data Comp: Off Server Time: 2026-11-02 23:30:39 UTC
