Page 98 of 150 1 2 … 96 97 98 99 100 … 149 150
Re: Bearing is In [Re: Canyonero] #1024638 05/04/13 08:29 PM
TOASTY Offline OP
Let me know if you need pictures or measurements.
Rectangular tube shaped like |____| with the corners like \_____/. Easy stuff, about 10' of 2"x5" or something. I have to price that steel vs something i already have laying around or can get a better deal on odd sizes like that can be expensive.
Re: Bearing is In [Re: TOASTY] #1024639 05/04/13 09:05 PM
PA_JERO Offline
I should be able to to pick you up if no body else closer is available, not a big deal. Are you flying into Phoenix?
Re: Bearing is In [Re: PA_JERO] #1024640 05/05/13 03:20 AM
Lloyd Swartz Offline
Yes, that would be Phoenix. I will set up a ticket this weekend...
Re: Bearing is In [Re: Lloyd Swartz] #1024641 05/05/13 07:13 PM
PA_JERO Offline
Sounds good lloyd.
On another note, Toast seemed to figure out the high idle issue. He had another TPS sitting around and another ISC, seemed to do the trick. We need to set the TPS to the correct place, again. also need to reset the idle screw. It sounds like he is gonna get the compressor and the tank mounted first so we can get the wiring finished up for that along with the front ARB air line. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Bearing is In [Re: PA_JERO] #1024642 05/06/13 03:27 PM
Great news! Ok, clock is ticking down now!
Re: Bearing is In [Re: Lloyd Swartz] #1024643 05/06/13 03:50 PM
monte3 Offline
Yeah, 2 years and an untold amount of labor... <img src="/forums/images/graemlins/smile.gif" alt="" />
Should be a capable truck, good job AZ Crawler Crew! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Bearing is In [Re: PA_JERO] #1024644 05/07/13 12:15 AM
Does he have a way to test the TPS? Mine also has a high idle issue (1800rpm) when in neutral/park but drops back down to 700 rpm when in gear. <img src="/forums/images/graemlins/confused.gif" alt="" />
Been too lazy to fix it since it hasn't seemed to impact anything too much. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Bearing is In [Re: off-roader] #1024645 05/07/13 02:36 AM
PA_JERO Offline
There is a test procedure but I don't know personally how to do it myself. I think Jay knows how or it may say in the FSM
But lloyds truck did idle at 1800RPM's or so. Also surged really bad. At this point all I know is adam changed out some spare TPS and ISC stuff he had lying around and it seemed to work.
So did you buy your ticket for the 31st of May lloyd?
Re: Bearing is In [Re: PA_JERO] #1024646 05/07/13 02:54 AM
TOASTY Offline OP
We're gonna take the day off like a couple of jerks.
Re: Bearing is In [Re: PA_JERO] #1024647 05/07/13 05:18 AM
Mine isn't surging but it is a consistent 1800 rpm in neutral and 700rpm when in gear. <img src="/forums/images/graemlins/confused.gif" alt="" />
Jay, any insights you can share? I'll move my question to the main tech forum as well if you think it will be a long explanation...
TIA!
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.030s Queries: 16 (0.027s) Memory: 0.6503 MB (Peak: 0.7760 MB) Data Comp: Off Server Time: 2026-11-02 15:59:30 UTC
