Page 112 of 150 1 2 … 110 111 112 113 114 … 149 150
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024778 07/03/13 02:02 PM
PA_JERO Offline
Keep us posted man.
Re: Wrench fest for Lloyd [Re: PA_JERO] #1024779 07/03/13 03:50 PM
Lloyd Swartz Offline
Will do. I tell you, I really like the 4.90 right now as well, seems to just feel right. Lets see how a high mountain road trip goes with the engine firing on all 3.5 squirrels today. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024780 07/03/13 05:02 PM
TOASTY Offline OP
Me and JBFP usually do the 'ol 6k and 75-80mph up the steep grades to flagstaff. <img src="/forums/images/graemlins/lol.gif" alt="" /> DOHC rocks!
Re: Wrench fest for Lloyd [Re: TOASTY] #1024781 07/03/13 05:40 PM
Well, I don't think it's near 6K, but it'll pull 4-4500 rpm all day long. I like to use the "power" setting on the transmission, too, for better shifting. Lock out O/D on anything steep. Of course I still have 4.6x gears and that makes my trans gearing really wide spaced pushing 35's.
Re: Wrench fest for Lloyd [Re: JohnnyBfromPeoria] #1024782 07/03/13 06:07 PM
I was thinking that as well John. 4.90 with 37's seem to be really good, I think you would like them. The 3.0 craved the 5:29, but I am not convinced 35-37 on the 3.5 DOHC is needed. Up by Purgatory Ski area there is a section you are lucky to make 35mph in a Lambo <img src="/forums/images/graemlins/scared.gif" alt="" /> Now that is steep.
Re: Wrench fest for Lloyd [Re: TOASTY] #1024783 07/03/13 09:27 PM
wrenchwench Offline
I do 2100 at 75mph up those hills.. but I have 1" tires <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Wrench fest for Lloyd [Re: wrenchwench] #1024784 07/04/13 02:59 AM
TOASTY Offline OP
Well Lloyd ran into problems with this very topic. While powering up a steep hill something happened but i'm not sure what. He first called and said he toasted his motor BUT when i talked to him again he had gotten it running enough to drive it to a motel....
The first conversation was a little weird because the phone was cutting in and out so those of you who got the roached motor text that was what i was going by. Let's hope that's not the case, anyone think of anything that could cause it to run like crap after a long steep hill climb?
Re: Wrench fest for Lloyd [Re: TOASTY] #1024785 07/04/13 03:13 AM
Better signal here, on my phone. About 90% sure major damage. But hardto tell right now. Someone is grabbing the titan and a trailer in the morning, will drop at shop Friday morning.
or
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024786 07/04/13 01:17 PM
lordtrunks Offline
i'm guessing bad coil pack or bad spark plug boot if lloyd got it running to limp back to hotel chances are it isn't timing but anything is possible nothing like a good ole bearing cap letting loose on you to ruin a weekend. Now i'm sure you had your shop put in a new timing tensioner when they redid the timing right lloyd?
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Wrench fest for Lloyd [Re: lordtrunks] #1024787 07/04/13 04:43 PM
Ok, been a nightmare of epic proportions. One place with a car hauler that is open in the Western hemisphere and the girl was passed working a holiday and refused rent. Waited a few hours more , complained to uhaul, made a bogus reservation
..still fought us.....anyhow our rescue tow is on the way. Hopefully we can get it on the trailer, may have to winch it on. Yes we drove it a few blocks to the motel, with it shutting of constantly and ratling like crazy . Sounds like at least top end damage. I suggested the tensioner, but they said it looked ok. If that is the problem it should be warranty.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.036s Queries: 16 (0.032s) Memory: 0.6527 MB (Peak: 0.7743 MB) Data Comp: Off Server Time: 2026-11-02 10:27:37 UTC
