Page 116 of 150 1 2 … 114 115 116 117 118 … 149 150
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024818 07/07/13 12:08 AM
There's a couple of internal differences on a Diamante engine, right? I think I remember a different cam grind at least.
Externally, there's bound to be more than a few differences.
Re: Wrench fest for Lloyd [Re: JohnnyBfromPeoria] #1024819 07/07/13 12:33 AM
Canyonero Offline
I can't be sure about this, as I never dug into it further than theory, but when I was searching around for a short block, even though the blocks for the Diamante, Kia Sedona, etc.. were essentially the same: All the engines I found in the junkyards were not identical to the Montero. Some of the motor mount bosses, and the bolt holes were in different spots, and AC bolt holes were not drilled in the block.
Hang in there Lloyd, I know what you're going through, and it isn't easy. You'll get it fixed up.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Wrench fest for Lloyd [Re: JohnnyBfromPeoria] #1024820 07/07/13 12:33 AM
Lloyd Swartz Offline
The biggest problem if I recall is that different power band. Seems like someone did the swap and was not happy with the results.
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024821 07/07/13 12:59 AM
ryany Offline
I'm not sure if there were different head designs (valve size, combustion chamber shape, compression ratio) for the various applications, but assuming the heads are the same, swapping the cams and intake/exhaust manifolds should yield the same powerband as the Montero motor has.
It seems like the Montero engines command a premium for some reason, while the same engine in a FWD configuration is far cheaper.
95 Montero SR
Re: Wrench fest for Lloyd [Re: ryany] #1024822 07/07/13 09:42 AM
lordtrunks Offline
diamante use different cams and also use a dizzy to name a couple things
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Wrench fest for Lloyd [Re: lordtrunks] #1024823 07/07/13 06:12 PM
ryany Offline
Ewwww.....distributors - Yuck!
95 Montero SR
Re: Wrench fest for Lloyd [Re: ryany] #1024824 07/07/13 06:37 PM
Not sure when it would be in the budget, but not soon. But how do these work out?
http://www.enginesus.com/ejsp/items...nginemake=mitsubishi&engineid=37
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024825 07/07/13 07:00 PM
Holy crap Lloyd... Can't a guy catch a break?!? <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Wrench fest for Lloyd [Re: off-roader] #1024826 07/07/13 07:03 PM
LandRaider Offline
Take out LS1, and 700r4?? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Wrench fest for Lloyd [Re: LandRaider] #1024827 07/07/13 09:45 PM
TOASTY Offline OP
When the throttle body is on the back side of the motor it's tranverse, Email these guys BUY 4.0 STROKER
And have them build you a 4.0 like what is used in the Pajero Race trucks, money but money is power.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.038s Queries: 15 (0.034s) Memory: 0.6510 MB (Peak: 0.7593 MB) Data Comp: Off Server Time: 2026-11-01 11:29:59 UTC
