Page 126 of 150 1 2 … 124 125 126 127 128 … 149 150
Re: Wrench fest for Lloyd [Re: matseel] #1024918 10/06/13 02:20 PM
Lloyd Swartz Offline
Hi Mat Steel. There is also a Newbie in ABQ that might be coaxed into a trip sometime. Still have to get these heads re-done. Maybe a spring Utah trip?
Moving to Colorado next summer, but will still be doing Colorado and Utah trips...
Re: Wrench fest for Lloyd [Re: matseel] #1024919 10/07/13 01:58 AM
TOASTY Offline OP
I know a guy with a known good shortblock for sale if we can scrounge some heads, maybe pull the ones off the original motor and have them checked?
KEVIN????? thoughts?
Re: Wrench fest for Lloyd [Re: TOASTY] #1024920 10/07/13 04:11 AM
The block may be just fine. I thought the idea was just to scrounge up a set of heads and get them rebuilt, and try to just install them....
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024921 10/07/13 04:14 PM
Why not just get some Clearwater heads. Good luck finding a quality machine shop for Mitsu heads that won't screw things up.
Re: Wrench fest for Lloyd [Re: JohnnyBfromPeoria] #1024922 10/07/13 04:44 PM
lordtrunks Offline
So far Johnny Rackley's has been proving they know how to work on mitsu heads kevin has had good luck with them rebuilding 2.6 heads. I guess HD's by my house seem to be a good shop but man i had work done by them and so did tay they have pretty strong opinions about imports and will let you know them from the time you come in untill the time you leave. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Bill's cylinder head on the other hand is the shop to stay far away from.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024923 10/07/13 04:49 PM
TOASTY Offline OP
My thoughts are what if your heads are good and your block is bad? This is coming from thinking about how a vehicle runs with a separated connecting rod.
Your call though since you actually have the truck to look at and have probably experienced every kind of failure ever on a vehicle so i'm sure you have a good idea.
Re: Wrench fest for Lloyd [Re: TOASTY] #1024924 10/07/13 10:17 PM
I am a bit scared of Clearwater heads. I believe my last set was over bored causing my old 3.0 3K rebuild to turn into a gutless, over heating disaster. If we have a good shop to do them....
No guarantees on the block, but it is a gut feeling it is ok. Nothing in the oil, truck was driven around, scoped the cylinders and while not a completely clear picture looks ok.....It is a gamble, but a lot less complicated then finding, putting together, and getting a full engine out here...
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024925 10/08/13 04:36 AM
TOASTY Offline OP
Sounds good, Kevin want me to come help you pull those heads?
Re: Wrench fest for Lloyd [Re: TOASTY] #1024926 10/08/13 05:57 AM
PA_JERO Offline
We'll use Johnny Rackleys, They haven't failed me yet so far, I've used them twice and clay used them once and seems to do good work. If you want to come over and give me a hand with the heads your welcome to it. We need to get valve stem seals and cam seals front and rear for the heads before we take it to the shop. They will need those.
Re: Wrench fest for Lloyd [Re: PA_JERO] #1024927 10/08/13 09:59 PM
Ok, let me know when I need to pay for something....
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.045s Queries: 15 (0.041s) Memory: 0.6561 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-11-20 00:15:43 UTC
