Page 133 of 150 1 2 131 132 133 134 135 149 150
Re: Wrench fest for Lloyd [Re: PA_JERO] #1024988 01/28/14 03:26 PM
Lloyd Swartz Offline
If we did not do it last time we probably should. If they were new last time, I would say no...
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024989 01/28/14 03:54 PM
PA_JERO Offline
We didnt replace any of the timing components or belt, we also never replaced the water pump which is recommended to do with the belt and tensioner. Timing kit and pump can be ordered through rockauto. I think i ordered the beck/arnley timing kit and a aisan water pump.
Re: Wrench fest for Lloyd [Re: PA_JERO] #1024990 01/28/14 04:24 PM
Ok, I will order those parts and get them here. Let me know if you think of anything else we should have on hand.
Re: Wrench fest for Lloyd [Re: PA_JERO] #1024991 01/28/14 04:28 PM
TOASTY Offline OP
PA_JERO, what are the chances that the old tensioner failed on Lloyd like what happened to Mark in Payson that one time?
Re: Wrench fest for Lloyd [Re: TOASTY] #1024992 01/29/14 02:51 AM
That's my guess.
Re: Wrench fest for Lloyd [Re: JohnnyBfromPeoria] #1024993 01/29/14 04:03 AM
haztoys Offline
That's my guess.
Man how many times do I have to say this ... "NEVER" reuse a Mitzu 'rubber bladder tensioner' if it has any time on it ... NEVER.... Read the FSM and you will see a very detaled way to deal and reuse one .. (hope I do not come across as a jurk ..just trying to help... <img src="/forums/images/graemlins/confused.gif" alt="" />...)
Re: Wrench fest for Lloyd [Re: haztoys] #1024994 01/29/14 05:34 AM
Actually, not likely. The shop that did the timing belt is really good, and they check the timing and it was fine.
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024995 01/29/14 03:25 PM
Ok, Asin pump, beck arnley hydraulic tensioner, and a belt with related pieces on the way. Got complicated again the way the packages are to get the good stuff.
Anything else you think of....let me know. Will check on fluids soon.
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024996 02/06/14 09:59 PM
About 1 month to go. Got all those other parts in. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1024997 02/08/14 07:20 AM
PA_JERO Offline
Yep, i think were good to go on our end. I think the last order of business is to get the heads to the machine shop. Which i am finally ready to drop off. Had to sort through the heads and make sure there gonna have plenty of valves to sort through seeing how all the valves on your old motor were bent or broken. I will have the heads in monday or tuesday and they should only take a few days so stand by. I will call you lloyd when there done and you just have to call them and pay over the phone.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.035s Queries: 16 (0.032s) Memory: 0.6526 MB (Peak: 0.7751 MB) Data Comp: Off Server Time: 2026-07-14 21:44:53 UTC
