Page 150 of 150 1 2 148 149 150
Re: Back [Re: TOASTY] #1025158 04/13/15 12:02 AM
Lloyd Swartz Offline
Will check with Esther. Don't think she took many, just was not in the mode and busy spotting me, more then I have ever has to spotted on that trail.
Re: Back [Re: Lloyd Swartz] #1025159 04/13/15 10:39 AM
lordtrunks Offline
thats pretty wild that trail has got so hardcore, before it was doable with 31's.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Back [Re: lordtrunks] #1025160 04/13/15 02:11 PM
My least equipped Rocker was a 1983 with 31s and LSD, but also drove a 1990 similarly equipped. I OPENED the Rincon driving the 83, although I did hike from the Tank Trap area down that trip. It just boils down to a couple of epic storms that washed things away. 33's and a locker should be considered min now, but I was happy to have two lockers and 37's in the difficult spots. The trail was never easy, and in a group lesser equipped rigs can make it, but just may not have as much fun.
Re: Back [Re: Lloyd Swartz] #1025161 04/13/15 05:16 PM
I
IncorpoRatedX Offline
Hey Lloyd, not to thread jack, but did you get my PM? This board is a little screwy sometimes.
If not;
I wound up with the transmission that was in your red truck, i've heard info all over the place from a lower stall converter, to a bored out valve body. Any chance you remember the mods done to it? I know i'll have some work to do with it, just trying to get an idea of whats in it.
V45W - 1999, 3.5 sohc, winter package
L042G- 1987, 2.6 carb, auto - Cylon Raider
A112 - 1973 Galant Wagon - 4G63 Turbo, 5 speed
L023G - 1983, 2.6 carb, 5 speed manual 4WD
L028 - 1983, 4D55 turbo diesel 2WD
Re: Back [Re: IncorpoRatedX] #1025162 04/13/15 06:46 PM
I dont even see one in my messages. This board is really dying, we need to figure out when to make a coordinated switch to the portal. It had a lower stall toque converter set up supposedly, in the era before just knuckling down and doing gearing right. I dont think we did the valve body. That trans has very few miles on the rebuild I would say. Then again, the first time around the mechanic embezzled the parts and got the money back from the dealer....So who knows.
Re: Back [Re: Lloyd Swartz] #1025163 04/13/15 07:48 PM
I
I figured you didn't get it. Silly wire, I agree on making the switch, it's just tough.
Thanks for the info, that was the same recollection JBFP had. Guess I'll need to burn some sage and get the bad spirits away from the trans. <img src="/forums/images/graemlins/smile.gif" alt="" /> The low stall converter should pair nicely with my turbo diesel. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.031s Queries: 16 (0.028s) Memory: 0.6204 MB (Peak: 0.7076 MB) Data Comp: Off Server Time: 2026-07-13 04:32:52 UTC
