A/F ratio gauge help? #1025164 03/22/11 09:14 PM
Rauch_Off_Road Offline OP
I'm heavily considering the installation of an AFR gauge for the 3.0.
So heres what I want to know. My goal is to tune the mixture on a new VAFM so its within spec. Can I reasonably run a short band or do I need to go to wideband? I'm not looking at getting too crazy wtih this.
Whats a good setup?
(aka suprathepeg, aka Sean)
Re: A/F ratio gauge help? [Re: Rauch_Off_Road] #1025165 03/22/11 09:18 PM
G
Greg_Canada Offline
If you want it accurate - wideband.
If you want to make it as close to 14.7:1 as you can, go narrowband. Wont help you if you're trying to tune closed loop.
Look for an AEM UEGO wideband... usually can find for $150 bux... or check the classifieds on customtacos.com or yotatech for a good used wideband...
89 4Runner
Re: A/F ratio gauge help? [Re: Greg_Canada] #1025166 03/23/11 04:30 AM
Snowtoy Offline
Yes, you will need a wideband A/F if you are going to use the meter to tune the engine. The non-wideband type cycle between lean and rich when at idle or when cruising, peg at rich when at heavy/full throttle, and work better as fuel economy monitor than a tuning one.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5930 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-06-07 03:41:48 UTC
