guess these vehicles don't like high water
#1025497
03/27/11 02:03 AM
lotta rain here. Thought I'd try out Grampa's pond,,,an low area on a local road that fills up in the spring. About 2 1/2 feet deep , just enough to fill the cabin about 3". I guess starter motors don't like that much of a drink... Glad I relocated my ECU a few years back.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: guess these vehicles don't like high water
[Re: KrzyDav]
#1025498
03/27/11 10:32 PM
i guess clutch doesn't like it either. Grabby like the clutch on my pops 3 cyl diesel kabota.
[Re: KrzyDav]
#1025499
03/27/11 11:16 PM
I went wheelin with a someone who had a manual Monty years back. He went through some decently deep mud and had chatter/slippage issues after that. I think he ended up cleaning things through the inspection hole in the bellhousing. Either that or dopping the trans, either way it sucked.
[Re: Jamez]
#1025500
03/28/11 01:27 AM
I'm glad that I've got an automatic. I've had mine in that deep of water, and my problems seem to be electrical from the fan throwing water on everything electrical.
[Re: Mudraider]
#1025501
03/28/11 01:31 AM
I'm thankful that my Monty leaks so much oil. Everything is encased in a hydrophobic sarcophagus that eliminates any potential water failure.
1992 Montero SR
[Re: Maxximtl]
#1025502
03/28/11 02:30 AM
Water is bad, avoid at all times.
[Re: 0778drz110]
#1025503
03/28/11 04:33 AM
Ive had water over the hood several times for a decent amount of time (driving through floods) and not a single issue, I also have an automatic I sealed off so that might be the key difference.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#1025504
03/28/11 05:28 AM
I accidentally drove my Montero through 4 feet deep salt water, but had no problems with the starter. The salt water in the valleys between the cams caused the ignition system to short out, but no starter problems. The water in the cabin completely shorted out the power seat relays and motors, the power door lock solenoids, the locking rear differential air pump, CD changer, and the ABS control module, but no starter problems. <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: KrzyDav]
#1025505
03/28/11 05:54 AM
I have been trying to relocate the ecu on my 89 raider but the wires aren't long enough. How and where did you put it?
1989 Dodge Raider v6 3.0 L, MT.
[Re: 0778drz110]
#1025506
03/28/11 06:33 AM
Bah, you simpletons with "ECU's" and "ignition systems", if you all had Benz diesels you'd be driving through it like nothing! <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
I need a snorkel now... just because...
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" /> 1988 Power Ram 50 2.6 Long Bed 1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
