Mileage?
#1025581
03/29/11 12:00 AM
What kind of mileage should I expect from a 96 SR on 33x10.5s? I just checked the mileage from my first tank with them on and I only got 12.5 mpg and that seems pretty low to me. I have no check engine lights and I accounted for the odometer difference due to the larger tires. It also only took approx. 18.5 gallons to fill up from the gas light. Is that about right?
Re: Mileage?
[Re: thatsnowinnebago]
#1025582
03/29/11 12:28 AM
What kind of mileage should I expect from a 96 SR on 33x10.5s? I just checked the mileage from my first tank with them on and I only got 12.5 mpg and that seems pretty low to me. I have no check engine lights and I accounted for the odometer difference due to the larger tires. It also only took approx. 18.5 gallons to fill up from the gas light. Is that about right? What kind of driving conditions and are you a lead foot?? In my case with 35" tires, I can get 15mpg on highway trips where I keep it under 75mph. In the city, mileage drops like a rock since you rarely get more than 10mpg when accelerating up to speed no matter how hard you try. Also bear in mind the difference in the stock tire and the 33's for your mileage. You need to multiply that to get the correct mileage. In my case, 35's are ~15% greater in size so I add 15% to my mileage and my speedometer speed. HTH.
Re: Mileage?
#1025583
03/29/11 01:53 AM
What kind of mileage should I expect from a 96 SR on 33x10.5s? I just checked the mileage from my first tank with them on and I only got 12.5 mpg and that seems pretty low to me. I have no check engine lights and I accounted for the odometer difference due to the larger tires. It also only took approx. 18.5 gallons to fill up from the gas light. Is that about right? I think you have to add 13% TO YOUR TOTAL MILES PER TANK. That is a pretty good size tire- What brand and type?
Re: Mileage?
[Re: sasnydley]
#1025584
03/29/11 04:57 AM
I get about 15 in my 95 SR, mixed driving on 33's. Sready 65 mph, maybe 16 or 17, depends on the wind.
Re: Mileage?
[Re: sasnydley]
#1025585
03/29/11 05:00 AM
I'm getting a consistent 15-16 mpg after adjusting for the 35" tires I have.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
Re: Mileage?
[Re: ryany]
#1025586
03/29/11 05:19 PM
I pretty much always get 15 in town and 16-17 highway depending on wind or hills. I have 35x13.5 M/T and 4.90 gears and my speedo is dead on.
Re: Mileage?
[Re: TOASTY]
#1025587
03/29/11 07:16 PM
I am getting 11mpg right now in my Gen1 LWB on 31s... I have to do some sniffing around to find the issue.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
Re: Mileage?
[Re: StockRaider]
#1025588
03/29/11 07:37 PM
9 mpg, don't feel bad <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Mileage?
#1025589
03/29/11 07:50 PM
14 in town and on the highway(go figure) with a roof rack and Don Bumper and winch on 31x10.5 bfgs and a horrible camber and tow in problem and sometimes throwing an o2 sensor code.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Mileage?
[Re: sasnydley]
#1025590
03/29/11 08:23 PM
What kind of mileage should I expect from a 96 SR on 33x10.5s? I just checked the mileage from my first tank with them on and I only got 12.5 mpg and that seems pretty low to me. I have no check engine lights and I accounted for the odometer difference due to the larger tires. It also only took approx. 18.5 gallons to fill up from the gas light. Is that about right? I think you have to add 13% TO YOUR TOTAL MILES PER TANK. That is a pretty good size tire- What brand and type? I've got a set of BFG ATs on there.
