Page 2 of 4 1 2 3 4
Re: milage lost [Re: bingocouple] #1025745 04/01/11 04:31 PM
2002_Sporty Offline
Yes. I am also experiencing the 180 Miles per tank.
I noticed this horrible change in MPG just a couple weeks ago. I can't get my rig to go over 65MPH. Not like I need to, but it's not normal. I also noticed the RPM's are at like 25,000 when I go up hill and down hill and on level ground. What's the deal?
I'm gonna try what you guys are doing in the posts above and see how it goes.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: milage lost [Re: bingocouple] #1025746 04/01/11 06:02 PM
homerdog Offline
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: milage lost [Re: 2002_Sporty] #1025747 04/01/11 07:03 PM
logansportage Offline
Mine has the same problem, but the cat is not the main problem. I'm losing pressure in two of the cylinders which puts me at 50%+50%+100%+100%=3/4 power.
homerdog great article. I'm going to try that too. Maybe I have a plugged cat too, but the leak down test I did revealed bigger problems up stream.
Re: milage lost [Re: logansportage] #1025748 04/01/11 09:27 PM
bingocouple Offline OP
well I just changed the plugs and the IAC control module. Seems to idle better now anyway. Now I am off to the auto parts store for gear oil and a pump.
When I took the plugs out, all looked normal, except for #4, there was oil all over the threads but none on the firing part. So I am suspecting the valve cover gasket is leaking a bit more now. Time to change it.
Re: milage lost [Re: bingocouple] #1025749 04/01/11 11:48 PM
I'm going to change my valve cover gasket and the head gasket at the same time. That way I stop leaking oil onto #4 plug and close the gap between #1 and #2.
Re: milage lost [Re: logansportage] #1025750 04/02/11 01:48 AM
and whats the head gasket going to run you? having the head tested, shaved and hot dipped?
Re: milage lost [Re: bingocouple] #1025751 04/04/11 02:45 PM
well I got my milage back. I changed the plugs and the IAC. The fluids got changed as well. I am now back up to 20.5 mph to the gallon. I havent been able to get to the CAT yet, but I am going to be doing a full clutch kit later this week. Maybe I can get to the cat and see whats up with that.
Re: milage lost [Re: bingocouple] #1025752 04/08/11 10:03 AM
2002_Sporty Offline
Crawled under the Sporty this past weekend and removed the 2nd Cat. That's not the issue. Gotta wait for the weather to improve to get to the 1st cat. Bummer...
Re: milage lost [Re: 2002_Sporty] #1025753 04/08/11 04:33 PM
did you gut it? How did it work?
Re: milage lost [Re: bingocouple] #1025754 04/09/11 08:33 AM
2002_Sporty Offline
I removed the 2nd Cat and shined a light through it. Every tiny little hole was open without any buildup at all.
The Cat internals were made of a hard mettal compound. Not ceramic made like I'm used to seeing. I jammed it with a rod. No luck knocking it out. would be better to get a straight pipe replacement if this area is the issue.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6355 MB (Peak: 0.7425 MB) Data Comp: Off Server Time: 2026-07-10 00:10:34 UTC
