Page 1 of 4 1 2 3 4
Should I buy this truck. Help the newbie... #1025966 04/04/11 03:12 AM
fasteddy Offline OP
1989 Raider swb V6 a/t, bouncy seat, no HL washers, unknown if lsd, been seeing and chasing this truck since 1996. 3 owner, 3rd PO bought for daughter to drive, yr or two, truck overheated, well taught daughter pulled it over and parked it (HOW did he manage to teach her to do that and I've tried for 40yrs to teach that to my wife....), went and picked her up, irked to the max, called the wrecker and it's sat on their storage yard for over a year untouched. Smoking some when she parked it, water pump done the week before (and no new oring, just a front half). One valve stem broken on aftermarket extra offset 10" wheels, 3 year old (over one of which it was parked) GY a/t's still have the little rubber teats.
Vanity tag, "TONKA89". Guess what color it's painted. Perfect body, perfect bumpers with ends trimmed to fender well line, tbar cranked.
Originally a red/gray truck. John has found a 95sr part out for 350, missing some intake parts, and all he wants is the front diff, so I get the spindles, rotors, caplipers, backing plates, upper a arms (and the chance to see if the adjustable gen 1 upper a arm pivot and bushings will fit the no caster adjustment gen2 upper a arms). Oh, and I get the rear air locker and the rear disc brakes (do I want the gen2 booster and MC and valves?). and the power front seats. Gonna hate to give up the multifold rears. Maybe pulling a trailer instead of loading up the back end will let me do that.
Oh, yeah, it is (was I just got off the phone and locked it down) $1500.
For those of you with no imagination, the CL ad...
I wish it had a radio...
Free at last, good God Almighty, free at last...
The plans:
Initial repair. Pull the intake, pull the valve covers, retorque the cylinder head bolts, do a cooling system pressure test, repair as necessary (fingers crossed and quite hopeful that fixes it) reseal the intake. and do ngk plugs and wires, new cap and rotor, water pump complete and new oring, timing belt/tensioner/front main seal/new improved final version crank bolt. New oem thermostat. New hoses. Test fan clutch. change engine fluids, check tcase/tranny/diffs fluids. Radio/cd. Spare tire. Jack.
Stage two, find a good tank gen1 a/t radiator core for the tanks (hint, hint <img src="/forums/images/graemlins/smile.gif" alt="" />) and do a 3 row core, all fluids, the SR locker and front susup/brakes. SR seats and adjustable shocks. better tailer hitch. rock sliders. 2 inch body lift. gen 1 lockup converter tranny. front and rear bumpers like a don's - john has Powell's old don rear for a pattern (is that ok, Don?). snorkel. CB. Rack.
Stage 3: The goRaider. I've got Charlie slowly putting together a plan for a single pside turbo exhaust manifold made from a heavy flange and sch40 steel weld fittings for the 3.0 rwd motor, with a crossover pipe fabbed from the dside downpipe at the wye to the base of the turbo intake, 2.5" exhaust from there to the rear, no cats, magnaflow muffler, MS fuel and spark control. 3000TT pistons, or custom 8:1's. 16g turbo. Potential for well over 300hp on pump gas. Chilled water/air intercooler, running off the a/c freon system. Cibie 7" conversions, one fog, one driving beam in hella 500's. John has an old Warn winch in the 82xx series for the new bumper.
Oh, yeah, a set of the Aisins or the new Rocky Ridge front hubs.
Have some thoughts about the selectrac tranny and awd locking cdiff, but I guess I'd need a sye and cv for that.
Folding roof tent to fit the rack, or a jeep trailer with same. Disco ladder. Jerry can and holder. RC magnet spotlight. tractor floods. wheel well led's. farm jack. laptop sturdy mount (gps, engine tuning on the fly, datalogging...), 2300w inverter and isolated deep cycle battery with starter boost interconnect. WWFF radio panel cut for gauges (oil temp, tranny temp, boost, fuel pressure - some of these are 1" gauges, some 2 1/16") switches (aux lighting options, shocks, rear locker) and cb. WWFF panel cut for aux gauge pod for oil pressure, aircraft style compass, and volts.
Re: Should I buy this truck. Help the newbie... [Re: fasteddy] #1025967 04/04/11 03:35 AM
ryany Offline
You know, you really should do a little more planning ahead instead of spontaneously jumping into things like this. <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR
Re: Should I buy this truck. Help the newbie... [Re: ryany] #1025968 04/04/11 03:41 AM
fasteddy Offline OP
I always wanted one of these trucks. I have lots of friends who own one, and I've been real impressed with them. Any good aftermarket sources? What are good tires and wheels? Are they easy to lower? Look like they'd jump real good. What is that knob under the driver's seat front for? It has a ticking sound from the motor. Where do you put the Type R embellem (sic)?
Will 'dubs fit ok? Can I get gears for it? Why doesn't it have any springs in the front?
I've got a 3' woofer to put in the back...
Re: Should I buy this truck. Help the newbie... [Re: fasteddy] #1025969 04/04/11 03:58 AM
W
willwinchforfood Offline
And if you don't hurry your azz up and get money to him it will be gone unless you took care of it today. I'll send you the autocad panel files to mess with and get Nate to tell you what metal to order for the sliders.
Your ever obedient son
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Should I buy this truck. Help the newbie... [Re: willwinchforfood] #1025970 04/04/11 04:02 AM
fasteddy Offline OP
He says it's mine. Money and sales contract tomorrow, good Lawd willin' and the deposit shows up in the account on time. Your ever attentive father. You taught me early to listen. Never had quite the knack of teaching you to do so <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Should I buy this truck. Help the newbie... [Re: fasteddy] #1025971 04/04/11 04:44 AM
hay nubie, i have som raditar i can give yu 4 this porject
<img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Should I buy this truck. Help the newbie... [Re: rxinhed] #1025972 04/04/11 05:06 AM
fasteddy Offline OP
Y'all awh raght, evenin iffen y'all arah fum the Left Coast.
Re: Should I buy this truck. Help the newbie... [Re: fasteddy] #1025973 04/04/11 05:33 AM
Stay Aisin on the hubs. Jus' sayin'.
FastEddy, welcome to the 'Wire! 33's will fit without a lift!
Re: Should I buy this truck. Help the newbie... [Re: JohnnyBfromPeoria] #1025974 04/04/11 06:51 AM
fasteddy Offline OP
What headers fit this truck? WHy does it blow out clouds of blue smoke when you start it. I'm gonna buy a Jasper engine and put in it...
Re: Should I buy this truck. Help the newbie... [Re: fasteddy] #1025975 04/04/11 07:29 AM
don Offline
Nice project vehicle!
Feel free to copy the bumpers, imitation is the sincerest form of ....copying!
I'm not in a position to make them now, so you can hardly source them anymore, can you!
love these project rigs in the right hands.
Don
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6501 MB (Peak: 0.7811 MB) Data Comp: Off Server Time: 2026-05-27 20:07:05 UTC
