front wiper arm removal
#1026132
04/06/11 09:14 PM
Can't remove front wiper arms after using PB blaster due to terrible rust. Was able to remove nuts but arms still stuck on threaded shaft. Any pullers or advice?
85 4runner, 22re,cam, headers,2.25free flow exhaust,3"susp lift, 33's,custom bumpers,& stuff
Re: front wiper arm removal
[Re: toyrker]
#1026133
04/07/11 12:27 AM
Soak it with PB Blaster and let it set overnight.
"Serenity through Sobriety"
[Re: OOP'S]
#1026134
04/07/11 07:32 PM
Tried PB 2 days with intermitent <img src="/forums/images/graemlins/confused.gif" alt="" /> spraying..no luck. How can I pull these? After spraying and not loose. I live at the beach and there is harsh salt air.
[Re: toyrker]
#1026135
04/07/11 07:42 PM
If you have a small torch, try heating up the center stud until is smokes a little and see if that will free it up. Make sure not to heat anything non-metal and use a small pin-point flame/pencil torch (like below), not a big flame/tip like you screw into a larger tank. ![[Linked Image]](http://www.harborfreight.com/media/catalog/product/cache/1/image/370x/9df78eab33525d08d6e5fb8d27136e95/i/m/image_945.jpg) And when it is hot, try melting a little candle wax onto the center and let that wick down into the splines. Should be able to find a small puller at a hardware/auto parts store that may work as well.
[Re: toyrker]
#1026136
04/07/11 07:43 PM
Heat? Make sure you cover everything up well tho. a puller would work too if you had one.
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
[Re: toyrker]
#1026137
04/08/11 03:36 AM
<img src="/forums/images/graemlins/cheers.gif" alt="" /> Found a puller at the ACE hardware.. It is used to pull faucet handles off of threaded shafts. Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
