Logging into 4x4wire from Droid #1026543 04/14/11 03:44 AM
stony-man Offline OP
I had to replace my Droid the other day. I have been unable to login to this site since. It says my username/password combo is not valid. I'm POSITIVE I'm entering it properly, and I never had a problem from the phone before. Anyone know what gives?
Re: Logging into 4x4wire from Droid [Re: stony-man] #1026544 04/14/11 11:08 AM
FrankR Offline
I just had the same experience on my home PC. Sounds like a login issue on the wire.
Frank
Re: Logging into 4x4wire from Droid [Re: FrankR] #1026545 04/14/11 05:31 PM
4x4Wire Offline
It is more of a login issue with your cookies.
Under the "MY HOME" tab is a "Main Configuration" panel. The bottom line is titled: Maintenance and has a selection "My Cookies"
Select that and then select the option to "expire cookies". You will be logged out and it should clear all of the session cookies.
It is the session cookies that can become corrupt and cause weird problems with login and display.
I have had a periodic problem with my Droid phone but no problems with my iPad.
Any problems, drop me an email as I periodically have to expire cookies for someone's login.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Logging into 4x4wire from Droid [Re: 4x4Wire] #1026546 04/15/11 04:19 AM
Thanks! I expired my cookies here, and that didn't do it. But your advice made me think to do the same on the Droid, and that did it. I cleared everything I could from the phone, and I was able to login immediately. Thanks again!
Keith
Re: Logging into 4x4wire from Droid [Re: stony-man] #1026547 04/15/11 01:11 PM
Dandeman Offline
Toyota Moderator
I regularly log into 4x4wire.com using my Droid-X without any problems.. So would agree, must be a cookie related issue, or incorrect saved password.....
Getting inadvertent wrong passwords out of the browser can be a problem sometimes....
Re: Logging into 4x4wire from Droid [Re: Dandeman] #1026548 04/16/11 07:09 PM
Creeper Offline
Any thoughts about adding a Tapatalk plug-in for the forum? Makes surfing forums from a phone really nice & simple. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: Logging into 4x4wire from Droid [Re: Creeper] #1026549 04/17/11 06:07 AM
4x4Wire Offline
I will check out the compatibility...
John Stewart
Editor - 4x4Voice
Re: Logging into 4x4wire from Droid [Re: 4x4Wire] #1026550 04/17/11 06:19 AM
4x4Wire Offline
After reading the info, TapaTalk is not compatible with the ubbThreads forum software.
There is an effort to make it available in coming upgrades to the forum. However, it appears there will be a development cost with a server side requirement that is not clearly defined.
So, currently, it cannot be implemented. I will keep watching the development progress.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 6.087s Queries: 15 (0.009s) Memory: 0.6248 MB (Peak: 0.7239 MB) Data Comp: Off Server Time: 2026-07-15 23:54:15 UTC
