Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS
[Re: 87monty]
#1026659
04/16/11 05:41 AM
I know this is off topic but here is my trailer. This is the hatch side and needs more bracing but is coming along... ![[Linked Image]](http://i64.photobucket.com/albums/h163/hyboosa/100_3313.jpg)
2003 limited 20 year anniversary 96 SR 87 Montero SWB=Turbo diesel 4BT T19 4sd with 205 transfer case
[Re: 87monty]
#1026660
04/16/11 01:31 PM
That is one masterful piece of work. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Keep the pics coming. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
[Re: JAVYPRO]
#1026661
04/16/11 04:14 PM
Thanks Javy for the comment, This trailer is going to be so cool I cant wait. I could post a new link on the build if you guys have intrest in it. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: 87monty]
#1026662
04/16/11 04:36 PM
I recently replaced my rotors and entertained the idea of drilled/slotted product. One of the better product I found was through "stainlesssteelbrakes" : http://www.ssbrakes.com/They claim the problem of cracking is reduced through their manufacturing process. I ended up going with OEM product, mostly because of the price. Occasional use of brake cleaner (especially after wheeling) really helps with squeaking pads/rotors when you don't have hose handy to rinse them down. Good Luck
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
[Re: 87monty]
#1026663
04/16/11 05:14 PM
Nice trailer!!! I have always wanted one like that.
[Re: 87monty]
#1026664
04/16/11 05:44 PM
I could post a new link on the build if you guys have interest in it. <img src="/forums/images/graemlins/smile.gif" alt="" /> A build thread would be cool. Nice trailer!!!
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: plh]
#1026665
04/16/11 05:56 PM
Jason,
I have a V6 brake setup for your Montero. Just sayin'
Russell
[Re: rxinhed]
#1026666
04/16/11 06:35 PM
If you didn't have your rotors turned when you replaced your pads, you could de-glaze your rotors with an abrasive pad attached to a grinder or drill - the techs at the dealership I used to work at would do this when a customer was having brake squealing issues. All you're trying to do is roughen up the surface, not to take off any significant amount of material off or put any deep scratches in it, so don't use anything too coarse. It's easiest to do it with the rotors off the vehicle but if you have a small enough pad you can just pull the caliper out of the way to access the back side. Make sure you have all the anti-squeal shims in place on the backs of the pads also, they really do work.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: rxinhed]
#1026667
04/17/11 01:37 AM
Jason,
Russell Russ I just might take you up on that! Thanks Guys on the trailer I will post a new topic today for everyone!
