Page 4 of 5 1 2 3 4 5
Re: Gen1 Transfer Cases Options [Re: willwinchforfood] #1026881 02/16/12 01:29 AM
dannytuned Offline
sorry 241or out of the rubicon tj
241or link
Slim chance finding one of those for a reasonable price.
4:1 gears are $600 for the Dana 300, cheapest 4:1 gearset.
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: Gen1 Transfer Cases Options [Re: dannytuned] #1026882 02/16/12 01:57 AM
There is an NPG249. It's a viscous coupler type. Has problems with the VC unit often and the 242 is the usual swap.
IIRC the three digits on NV/NPG tcases are as follows
first didgit = # of speeds, i.e., 1 is hi only, 2 is hi-lo
second digit = strength, the bigger the #, the stronger, so a 231 is weaker than a 242. I think they go up to about 7 or 8
third digit = type of center diff/torque splitter -
1 = Part-time 4WD
2 = Full-time 4WD
3 = Electronic shift
4 = Not currently used
5 = Torsen-type differential
6 = Computer controlled multi-plate wet clutch
7 = GeroDisc
8 = Not currently used
9 = Viscous coupling
I cheated and looked up the 3rd digit stuff....
Re: Gen1 Transfer Cases Options [Re: fasteddy] #1026883 02/16/12 02:13 AM
So it is looking like the Dana 300 is going to be my choice to facilitate the Toyota axle. Now to keep an eye out for the 4:1 gears.
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026884 02/16/12 05:04 PM
heathdogg Offline
I can give you the NAPA numbers. The connector is a 725176 and the terminals are (2) 725171 16-14ga wire or (2) 725150 for 20-18ga wire and (2) 725152 for the seals. The terminals have to be crimped on though. There is a connector that come with wire on it already a NAPA EC152/ Standard S172 but it is way over priced. Or snag one from a Grand Cheerokee. <img src="/forums/images/graemlins/smile.gif" alt="" />
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Gen1 Transfer Cases Options [Re: heathdogg] #1026885 02/25/12 01:15 PM
lordtrunks Offline
mudraider i'm trying to remember but i think when i was playing with my d300 when it was unflipped(pass drop) it cleared the floor just fine now running it driver side drop is a whole different story haha had to cut my floor and move my seat frame back. <img src="/forums/images/graemlins/shiner.gif" alt="" /> i still gotta order shifters for it i've been crawling under it to shift in and out of 4wd <img src="/forums/images/graemlins/notooth.gif" alt="" />
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Gen1 Transfer Cases Options [Re: lordtrunks] #1026886 02/25/12 10:37 PM
dannytuned Offline
When I took off my body lift I had to cut the floor to clear my flipped 300, but did not have to touch my seat, mines a Sport though. I might have been able to clock it down one notch but wanted it to tuck up as much as possible.
edit. I guess I would have had to do something with my seat if I wasn't running a doubler.
Re: Gen1 Transfer Cases Options [Re: lordtrunks] #1026887 02/26/12 05:57 AM
LT, picked up the Toy axle, this weekend. Dana 300, next weekend. gathering parts to leaf spring the front end.
Re: Gen1 Transfer Cases Options [Re: Mudraider] #1026888 03/02/12 12:12 AM
RECON45 Offline OP
I got a cable linkage set up and playing with the shifter trying to figure out its orientation. I was looking under the montero and notice 2 things. How has others work the body mount situation? The montero has a driverside body mount that the 231 does not have. Also with the automatic transmission the shifter linkage bolts up at this point as well. How has others addressed this? or did yall have manual trannys. Thanks.
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026889 03/02/12 01:05 AM
The "mount" on the dside is not a support, just a roll restrictor.
Time for a cable shifter for the tranny. Look at art carr.
Re: Gen1 Transfer Cases Options [Re: fasteddy] #1026890 03/02/12 02:06 AM
RECON45 Offline OP
Really. that is fantastic news about the mount is not an actual mount. i was wondering it did seems kinda flimsy or not as beefy as all the other things on the montero. I will see if I can retain the factory shifter set up, but that does seem to be a poorly design set up.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6442 MB (Peak: 0.7534 MB) Data Comp: Off Server Time: 2026-05-26 04:56:01 UTC
