Factory trailer hitch? #1027136 04/23/11 10:00 PM
StockRaider Offline OP
I remember over the winter I went to Reading PA to look at a 90LWB Montero with a buddy of mine. I looked at it and aside from normal rust here and there and a few oil leaks. The part that caught my eye was the trailer hitch. It was one that bolted to the 4 bolt mount and bolted to the frame. Was that factory? Or was this one of those John Baker hitches I heard so much about? It looked extremely stout and was tucked up behind the bumper enough to not drag on obstacles. I would love to find one to put on my LWB, but I am not sure where to look. Russ? <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Factory trailer hitch? [Re: StockRaider] #1027137 04/24/11 01:35 AM
ryany Offline
Use the search function - towing with Monteros has been covered many times, including everything from frame mounted hitches to the 4-bolt mounted style that you mentioned (which is what I use).
95 Montero SR
Re: Factory trailer hitch? [Re: ryany] #1027138 04/24/11 01:56 AM
I wasn't asking about towing, I just wanted to know the brand of hitch. I already searched and found no pictures. I already have a standard Curt receiver.
Richard E
1983 Honda XL600R
Re: Factory trailer hitch? [Re: StockRaider] #1027139 04/24/11 02:54 AM
Funny you mention seeing one on a 90. I found a 90 in a salvage yard with a frame mounted hitch like you describe. It is a very stout set-up. I had to make brackets to do the additional brackets that mount it to the frame. Plus had to clearance some of the metal to get the thing to fit. Quite a difference in the frame between the 6 cylinder and the 4 cylinder.
Re: Factory trailer hitch? [Re: Mudraider] #1027140 04/24/11 04:50 AM
I've had a few of these through my hands, some marked John Baker, others as Valley Products. I'm sure there were others. I have a Baker unit welded up to my Raider, very stout.
Re: Factory trailer hitch? [Re: rxinhed] #1027141 04/24/11 05:13 AM
KrzyDav Offline
that looks like the one on my V6. I got it off a LWB. Looks like you had to grind off some to mount it. Mine originally bolted up inside that flimsy OEM bumper, so was pretty useless added wieght. Mine is now integral to my home made bumper.
dave h.
Re: Factory trailer hitch? [Re: KrzyDav] #1027142 04/24/11 06:56 AM
Russ, next time you get a baker hitch mind holding onto it for me?
Richard E
1983 Honda XL600R
Re: Factory trailer hitch? [Re: StockRaider] #1027143 04/24/11 06:52 PM
I'll look for some of these hitches, two requests now... <img src="/forums/images/graemlins/smile.gif" alt="" />
I swapped one away last year for a smile, next ones will be more $$.
@ Dave, I did section out the corners of the wings. Welding to the frame gave this arrangement much better resistance to rolling out under loads. I've previously had Smittybilt and Baker pieces that were either ball mount or receiver type and only used the pintle mount. I bent all three towing my water tank trailer off highway. My present setup laughed at them other wimpy ones. <img src="/forums/images/graemlins/notooth.gif" alt="" />
R-
Re: Factory trailer hitch? [Re: rxinhed] #1027144 05/17/11 05:21 AM
That hitch works great. Towed another one home yesterday, 130 miles. Use it all the time with my Ford Courier bed trailer, loaded like crazy with scrap sometimes. The Gen 2 disc are the only thing I recommend if you are going to be pulling any weight. [img][image]http://i598.photobucket.com/albums/tt64/fastfoodvw/The%20Shogun/Shogun7.jpg[/img][/image]
Re: Factory trailer hitch? [Re: StockRaider] #1027145 07/22/15 05:12 AM
Rich...I know this thread ceased over 4 years ago. I have a 4-bolt John Baker ball mount hitch for sale...
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6429 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-10-22 00:14:59 UTC
