1999 Montero Sport PO421 code #1027198 04/25/11 01:35 AM
rollguy Offline OP
I have a PO421 code (warm up catalyst efficiency below threshold bank 1). Does anyone know what part/s would need to be replaced to fix it? I think it could be the catalytic converter, but it may be something simpler (O2 sensor?).
Any help would be appreciated. Thanks, Rich
All Diesel Fleet:
1985 Mitsubishi 2.3 Turbodiesel Pick-up, 1983 GMC Van- 6.2 Diesel.
Benzs: 1995 E300 diesel, 1980 300SD, 1982 300CD, 1983 300D, 1985 190D.
1980 AMC Eagle Limited Wagon powered by: 3.6 Litre I6 VM Turbo Diesel Engine (one of fewer than 10 made, only 2 known to still exist)
Re: 1999 Montero Sport PO421 code [Re: rollguy] #1027199 04/25/11 05:20 PM
What's the mileage and are you smoking from a valve guide seal issue? Perhaps the cat's plugged if you've been burning oil but honestly can't be sure. Hopefully someone else can chime in with some better ideas.
Re: 1999 Montero Sport PO421 code [Re: off-roader] #1027200 05/11/11 09:35 PM
rollguy Offline OP
No smoke that I know of. I wanted to find out if something simple may be wrong before starting to replace expensive parts. Also, does anyone know which side bank one is on? L or R?
All Diesel Fleet:
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5911 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-06-02 16:29:10 UTC
