89 2.6 Vacuum hose delete #1027502 05/02/11 03:49 PM
MadMax Offline OP
Ok guys I'm really tired of looking at this rats nest of vacuum hose, I do not have e check so I'm wanting to delete all I can... I know I need a hose for the vac advance, however what else can I remove? I have quite a small collection of the black caps that came on the carburetor from the factory. I plan on keeping all the emissions garbage just in case they ever put e check in place? I know I'll need to buy an egr block off plate, but please give me the run down on how to shed this mess of hoses?
Proud owner or driver of a 1989 Mitsubishi Mighty Max 4X4, 1989 Mitsubishi Montero SWB, 2008 Mitsubishi Endeavor, 2008 Mitsubishi Eclipse SE, 2007 Galant.
Re: 89 2.6 Vacuum hose delete [Re: MadMax] #1027503 05/02/11 05:53 PM
plh Offline
If your Mikuni is working properly - then you will need to retain the rats nest to maintain functionality. Swap on a Weber - then delete everything except the vacuum advance and the charcoal canister.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: 89 2.6 Vacuum hose delete [Re: MadMax] #1027504 05/02/11 05:57 PM
zarktheshark Offline
If you are running the stock carb, I'm not sure if you can. I know if you replace the carb with a weber, all you need is the vac advance, but the stock carb uses water to warm up the carb and that is all controlled by vacuum and the associated switches\sensors that go along with it. Someone else might know better, but since the stock carb is already finicky, I would be afraid of taking off any lines. Good luck.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: 89 2.6 Vacuum hose delete [Re: zarktheshark] #1027505 05/02/11 07:00 PM
MadMax Offline OP
Ahh man that sucks, I'm having problems getting the all connected properly, it's rather aggravating!
Re: 89 2.6 Vacuum hose delete [Re: MadMax] #1027506 05/03/11 02:21 AM
I have several detailed photos of the vacuum line arrangement for the 87 - 89 4-cyl. Just provide an alternate email address for me to dump them to.
Russell
Re: 89 2.6 Vacuum hose delete [Re: MadMax] #1027507 05/04/11 04:10 AM
Gonna drop a chain email with pics, anyone else? <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: 89 2.6 Vacuum hose delete [Re: plh] #1102832 01/23/17 12:49 AM
Maciek Offline
Had the weber on for almost a decade now, but just finally did the vac delete this fall (no more emissions since 2013). Pulled everything including the control box (bolting the e-choke relay back alone using one of the holes). I just have one vac hose from the carb to the advance on the dizzy, and had to run a couple to the purge control valve. I would like to delete the PCV and charcoal canister (maybe stick the compressor in it's place), but when i just capped them off i was getting pressure building up in the fuel tank, so I think you'd need a breather on the vent line from the tank, or a two-way vented gas cap (not just vacuum relief).
'88 Raider - 250+K | 2.6L G54B; no balance shafts, non jet-valve head, ARP head studs| Weber 32/36 DFEV | Pacesetter 4>1 | 2 1/4" magnaflow | 32" BFG A/T | 2" bar crank & add-a-leaf | +2 SkyJackers | bumpstop del | Optima Yellow-Top | Curt GenII receiver
Re: 89 2.6 Vacuum hose delete [Re: MadMax] #1102845 01/24/17 02:36 AM
The PCV must not be capped.
If you aren't concerned about emission controls anymore, the PCV and fuel breather systems can be vented to the atmosphere through a filtered common outlet.
See the K & N link for an idea.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6258 MB (Peak: 0.7266 MB) Data Comp: Off Server Time: 2026-05-27 20:41:37 UTC
