Gen II 3rd row seats #1027521 05/03/11 01:08 AM
bastardo Offline OP
When I bought my Montero, the 3rd row came included but not installed.
I thought I had all the necessary plastic bits but not the screws/bolts. But then this image just confused me more...
What screw/bolt do I need? part 76689E or 76698B? Is there a suitable alternative that I could grab from Home Depot?
Thanks!
95 Montero SR - 35" BFG KM2, 2.5" Suspension Lift, 2" Body Lift
Re: Gen II 3rd row seats [Re: bastardo] #1027522 05/04/11 06:28 PM
Thanks!
IIWU, I'd go to a local pick and pull yard and just grab what you need. Alternatively, you can always check with a local Mitsu dealership (if there are any around up there).
As for a HD alternative... not if you want it to be safe. I don't believe they have large enough metric bolts. Even if they did you want to be sure they're rated to the correct metric grade. I'm not sure what the grade is on those mitsu bolts but someone else on here could probably tell you.
Re: Gen II 3rd row seats [Re: bastardo] #1027523 05/05/11 12:27 AM
ryany Offline
Although the diagram is not all that clear about where there bolts go, I think you're looking for 76698B. The 76689E is a smaller screw that holds the plastic trim piece and the rubber bump stop in place.
95 Montero SR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5922 MB (Peak: 0.6467 MB) Data Comp: Off Server Time: 2026-06-09 17:04:23 UTC
