3vze Timing Belt recommendations, etc. #1027748 05/06/11 03:09 AM
Elbow_Greese Offline OP
Just bought my sister's truck - was my Dad's, new off the sales floor.
1994 2wd extra cab v6 5speed.
Only has 145k on it :-)
I need to replace the timing belt. Last time I know it was done was at 60k.
What brands/from where to purchase?
What else should I replace while I'm there?
Also, are there still headers made for these motors?
I haven't had time to look into it more, but I think I have an exhaust leak on the drivers side.
Thanks in advance!
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: 3vze Timing Belt recommendations, etc. [Re: Elbow_Greese] #1027749 05/06/11 08:22 PM
Staceman Offline
If you are going that far into it, I would also do Tension pulley, and idler pully. I went toyota for the belt, but pullies I went to parssdinosaur
Upper Idler
Tension Pulley, bearing only..
Re: 3vze Timing Belt recommendations, etc. [Re: Staceman] #1027750 05/06/11 10:30 PM
OOP'S Offline
Water pump.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 3vze Timing Belt recommendations, etc. [Re: OOP'S] #1027751 05/08/11 04:48 PM
G
Greg_Canada Offline
I would do everything mentioned above,
(belt, tensioner bearings, water pump) as well as thermostat and gasket(s), change the drive belts, and check everything else over (radiator, etc.)...
89 4Runner
PHP: 7.4.33 Page Time: 0.790s Queries: 15 (0.003s) Memory: 0.6007 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-06-19 09:26:38 UTC
