Re: extended front forks [Re: 4runnernomore] #1027762 05/21/11 03:56 PM
hadtomer Offline
I already have a serious lift on the rear. its really much more than 4 inches. on this forum people use jeep tj springs- at most - and we are talking about stock springs - and get 4 inches of lift. when i bought my rear springs i bought lift springs for the tj (2 inches)and not standard ones. as you can see from the picture- as the sporty looks right now- with a 1 inch spacer AND 2 inch lovells lift coils on the front - my rear end is still much higher than the front - about 3 inches higher!!!! (my friends call the sporty "the slide" cause the rear is so much higher than the front)
https://picasaweb.google.com/108546094129487904656/SportyDiffLock#5595005181047197186
of course i can fit an extra 2 inch spacer up front - and i have done this in the past - but it was hell on the cv boots. the driveshafts held quite well but the rubber boots kept tearing on the bottom of the forks- the reason it that a 3 inch spacer makes the whole shock and spring and fork assembly much lower- thus rubbing on the cv boot.
when i will fit the 3 inch lift coils AND the 2 inch forks i will take the spacer out- thus taking the shock uper mounting point to its original position- making sure i will have a serious lift without the rubbing my cv boots.
if the front will be higher than the rear (dont think so) than i will fit the forks with my current lovells 2 inch coils (also- they seem to have sagged a bit- so its probably more like 1.5 inch lift coils right now)
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock.
http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: extended front forks [Re: hadtomer] #1027763 06/04/11 02:12 PM
4
4runnernomore Offline OP
Still waiting on a reply to my email.
Hadtomer are you able to assist and let the shop know that I have sent an email regarding difflocks and extended ront forks??
cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5973 MB (Peak: 0.6468 MB) Data Comp: Off Server Time: 2026-06-07 11:28:32 UTC
