Page 18 of 30 1 2 … 16 17 18 19 20 … 29 30
Re: Teardown Day One [Re: Canyonero] #1028340 08/12/11 06:56 AM
Got my fingers crossed (again) that you don't have to strip this engine down much further, jinstv. Here's my hopes the cylinder walls/pistons look good.
Re: Teardown Day One [Re: JohnnyBfromPeoria] #1028341 08/12/11 04:40 PM
That?s crap, you should insert the damaged cam into the mechanics sphincter.
Re: Teardown Day One [Re: TOASTY] #1028342 08/12/11 05:43 PM
wrenchwench Offline
I don't know about the rest of you but 2 men 1 camshaft is NOT a video I'll be clicking in the near or distant future.
How does a leanin' lifter even happen in the first place? Did he just dump parts in there from a Yahtzee cup and tighten bolts?
Here's hoping the rest comes together smoothly now!
Re: Teardown Day One [Re: wrenchwench] #1028343 08/12/11 05:56 PM
ryany Offline
I had the same thing happen when I had my heads off to replace the valve stem seals back in 2005 - everything went together fine but after starting it up it was missing on one cylinder. I eventually found the exact same issue - my #4 cylinder intake rocker arm had somehow tilted off the pivot. I ended up replacing the intake cam and rocker arm and its been fine ever since.
95 Montero SR
Re: Teardown Day One [Re: ryany] #1028344 08/12/11 06:34 PM
Canyonero Offline OP
I'm not entirely sure how the rocker came off, but it was actually jammed into the side of the cylinder head. I had to use a screwdriver to pry it loose, and you can see where the rocker had embedded itself in the head. Would explain some of the noise I heard, but not the engine stalling after a few seconds. Does the ECU kill the engine if it detects too much knock from the knock sensor?
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Teardown Day One [Re: Canyonero] #1028345 08/12/11 07:05 PM
ryany Offline
I don't think it does - usually the ECU will just retard the timing until the knock disappears.
Have you checked your catalytic converter? A clogged converter could explain the engine's running for only a short period of time.
95 Montero SR
Re: Teardown Day One [Re: ryany] #1028346 08/12/11 08:44 PM
wrenchwench Offline
And a valve not doing its job could explain a clogged converter... but I've never seen a cat THAT clogged that it would make the engine shut off <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Teardown Day One [Re: wrenchwench] #1028347 08/12/11 09:29 PM
I experienced it once on an old Dakota that I had. Suspected the cat was bad after I had a valve job done. While it was running I smacked the cat with a hammer to break up the junk, and it clogged so bad that it killed the engine. But it has a very distinct sound. Since it passed emissions not 15 minutes before it died on me, I'm inclined to think it is ok, but I haven't had it running long enough to make that determination.
Looking up some parts just a new cam is $264 shipped from mitsubishiparts.net. Yikes. I'd be better off getting a Clearwater head in that case. Unless someone knows of or has a driver side intake cam they are willing to part with.
1995 Montero SR
2" Body Lift
Aisins
Re: Teardown Day One [Re: Canyonero] #1028348 08/12/11 09:40 PM
wrenchwench Offline
what about that one in my garage?
Re: Teardown Day One [Re: wrenchwench] #1028349 08/12/11 10:09 PM
Forgot about Lloyd's old engine. Can't hurt to pull the valve cover off and see what kind of shape it is in. I'm with the kids this weekend, but maybe I can check it out next week sometime once I get deeper into this engine.
1995 Montero SR
2" Body Lift
Aisins
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.014s) Memory: 0.6506 MB (Peak: 0.7759 MB) Data Comp: Off Server Time: 2026-11-07 05:53:56 UTC
