changing coil springs #1028516 05/14/11 01:48 PM
bingocouple Offline OP
can someone please post the procedure for changing the coil springs on the rear? I am looking for step by step instructions.
Thank you in advance.
Re: changing coil springs [Re: bingocouple] #1028517 05/14/11 03:06 PM
DennisThompson Offline
The first thing you need to do is jack up your Kia and put jack stands under your frame with the tires at off the ground or remove the tires. Then place your floor jack under your diff and jack up your axle but not enough to lift it off the jack stands. Remove your bottom shock bolts and let the jack down, your springs will fall out. Put in the new springs and jack up the axle enough to replace the shock bolts, take it off the jack stands and your done. The hardest is removing the rusty shock bolts.
Hope that helps, Dennis
Re: changing coil springs [Re: DennisThompson] #1028518 05/15/11 12:38 AM
I dont have to remove the panhard rod?
Re: changing coil springs [Re: bingocouple] #1028519 05/15/11 02:21 AM
No, the shocks are all that keeps them from falling out.
Dennis
Re: changing coil springs [Re: DennisThompson] #1028520 05/15/11 04:34 AM
ool, thank you. I will be buying the kit from everett soon and I am trying to get all the info I can right now. I went wheelin yesterday and ended up getting high centered, but if I would have had an extra 3-4 " I would have made it thru.
Re: changing coil springs [Re: bingocouple] #1028521 05/19/11 07:29 PM
jagerMR Offline
Bingo, Im in Portland area. If your anywhere close, id be happy to lend a hand. the rears are cake.
-Tim
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6050 MB (Peak: 0.6743 MB) Data Comp: Off Server Time: 2026-10-27 04:52:50 UTC
