Page 4 of 4 1 2 3 4
Re: Winch Shoot Out Non-Sense Rant [Re: theheep] #1028684 05/21/11 04:25 AM
ryany Offline
along with a tree strap
That's great as long as you're wheeling where there are trees. Az Crew would have to carry "rock straps". <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR
Re: Winch Shoot Out Non-Sense Rant [Re: ryany] #1028685 05/21/11 10:39 AM
StockRaider Offline
Has anyone found out if the optional PTO winch for the overseas mitsubishis work with the automatic transmissions? I see the access plate on the side of the transfer case, so it makes me want to know if its worth finding one overseas to bolt to my Raider. <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Winch Shoot Out Non-Sense Rant [Re: StockRaider] #1028686 05/21/11 05:08 PM
The gear isn't there to run the pto in the t-case, the t-case neutral position runs the pto. I took apart my auto t-case apart with Onsail and we noticed the lack of a PTO gear, i always thought that the gear would be there and once you bolted on the PTO the position on the shift selection would be there between L and H but it's not.
Re: Winch Shoot Out Non-Sense Rant [Re: TOASTY] #1028687 05/21/11 05:47 PM
Happy Birthday Lloyd Swartz Offline OP
Despite going electric, I just dont see the entire "if my engine is off or the truck is rolled over" argument. Self recovery from a roll over is really not practical for most, unless you have a buggy you can drag all over the place until it turns over. Then again, in over 20 years of wheeling I have been able to stay away from rolling, along with the groups I wheel with. And as the test shows, so many electrics die in the water anyways.....I have yet to see a fast Hydro set up. But even if you did, is it worth the effort and the complexity?
Re: Winch Shoot Out Non-Sense Rant [Re: LandRaider] #1028688 05/21/11 05:49 PM
[/quote]
Sparkem had an 8294 on his 94 SR in a Don's bumper?? Why would they be unmountable? [/quote]
To me those bumpers stick too far out for Rock Crawling...With enough lift it may not be as big a problem, but I am a fan of low profile.
Re: Winch Shoot Out Non-Sense Rant [Re: Lloyd Swartz] #1028689 05/21/11 09:57 PM
Just realized i need to be sending you pics of my LowPro bumpers for you to look through, i know you saw the tube one but not the other. sorry i dropped the ball on that one.
Back to winches, Lloyd have you looked into the Worm drive units? I think for your use and application they would be perfect.
Re: Winch Shoot Out Non-Sense Rant [Re: TOASTY] #1028690 05/21/11 11:59 PM
I never look at worm drive hydraulics. The T-max has machined, 3 stage plenatary gears. They are also rebuildable and have bearings instead of bushings. A few of the reasons I went T-max.
Probably prefer the bumper with hoops. I like the idea of bobbing the front. I guess a winch will fit ok in that opening?
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 1.557s Queries: 16 (0.005s) Memory: 0.6295 MB (Peak: 0.7367 MB) Data Comp: Off Server Time: 2026-06-06 20:20:05 UTC
