Driveline whir and whump problem... #1029495 06/01/11 10:38 PM
hacker Offline OP
'96 XJ 4.0 4wd here, and what I've been observing for at least the last year is a sort of whirr/whump sound exactly once every wheel rotation, that seems like it could be coming from any direction. At first I thought it was a broken tire band, so I replaced each tire in succession with my spare to see which one it was only to determine it's not any of them. The sound persisted.
Next, since my front axle u-joints were looking bad I thought it might be them. Got some new ones in and the sounds still there.
Last, on a whim, I replaced both my front hubs. Sounds still there.
Now for the first time, what I noticed this week on really smooth road, is that at slow speed you get a slight up and down sensation in the seat in conjunction with the sound.
Now all of this is beyond me, but hopefully there's enough info. here for someone to make a decent guess.
I'm all ears. Thanks.
Re: Driveline whir and whump problem... [Re: hacker] #1029496 06/02/11 01:18 AM
4x4Wire Offline
I would be looking at transfer case mounts and rear drive shaft.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Driveline whir and whump problem... [Re: hacker] #1029497 06/06/11 07:03 AM
BobRowe Offline
I agree with John. It's likely either: (1) Loose t-case or tranny mounts; (2) Bad u-joint(s) on rear drive shaft; or (3) a bent rear driveshaft. It could also be a bad pinion shaft bearing on the rear diff, but that's not as likely.
PHP: 7.4.33 Page Time: 0.557s Queries: 15 (0.009s) Memory: 0.5933 MB (Peak: 0.6471 MB) Data Comp: Off Server Time: 2026-07-15 14:51:56 UTC
