Page 2 of 3 1 2 3
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mike5] #1031139 07/04/11 02:33 AM
StockRaider Offline
Check for cracks on the Vac lines for the fuel pressure regulator. Sisters blazer wouldn't budge until I replaced it. Same went for my Montero after the rebuild I didn't have the line connected and it wouldn't start because of it.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: StockRaider] #1031140 07/04/11 06:58 PM
mike5 Offline OP
Monday update: I did as MX suggested and got to the fuel pick up line. Given how it is attached and where a metal bracket/support is, I Could only see 2/3 of the hose. But what I could see looked like the hose was like new. No cracks or anything like that.
MX: Can I borrow that spare ECU you have and test it out?
Thanks again.
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mike5] #1031141 07/04/11 10:34 PM
mxmikie Offline
you removed the fuel pump from the tank and looked at the 2 inch hose going from the fuel pump to the steel fuel tube in the tank ????
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mxmikie] #1031142 07/04/11 11:09 PM
If the rubber fuel line from the tank to the frame mounted steel line has a crack, you will see it, a roaring spray of raw fuel.
Mx is talking about the small rubber hose INSIDE the tank, which you get at this way. Using flare nut wrenches, remove the fuel lines from the plate on the tank, disconnect any electrical connectors and unclamp and remove any small vent lines. Then remove the screws that hold the plate that holds the fuel lines, the pump, and the fuel pickup from the tank/plate, rap the plate sharply to break the gasket seal, and pull it out of the tank. It's several inches long down into the tank, and you'll see the two fuel lines, the fuel pump, and the fuel pickup screen, all hosed and clamped together. The small rubber hoses that splice the pump into the fuel lines must be suction tight on the pickup side, and pressure tight with clamps on the output side. MX is talking about the one on the engine side of the pump. It can have intermittent leaks that kill pressure, mostly temp dependent.
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: fasteddy] #1031143 07/05/11 09:56 PM
mike5 Offline OP
Just to confirm, this is what I did:
1. Pull carpeting back
2. Remove access plate
3. disconnect electrical harness on big access plate
4. Remove small nuts from said plate (maybe six or eight of them)
5. Without disconnecting the two fuel lines, pulled entire unit out about 4 inches or so (I could see the gasoline/liquid), looked into the hole with a light and I could see a 2" or so rubber hose in the middle, below which was a mental attachment I believe
Anyway, this is the hose I looked at and it was wet and looked new to me...as in not worn out. Obviously the car was not running and the fuel tank had released all the pressure when I lifted the top plate.
So are we talking about the same item?
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mike5] #1031144 07/05/11 11:38 PM
mxmikie Offline
yes change that hose that looks new
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mxmikie] #1031145 07/06/11 12:05 AM
mike5 Offline OP
I see. Is there a part number or is it a generic fuel line?
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mike5] #1031146 07/06/11 01:40 AM
mxmikie Offline
its 5/16 fuel injection hose do not use regular fuel hose http://cgi.ebay.com/ebaymotors/Goodyear-...sQ5fAccessories
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mxmikie] #1031147 07/06/11 01:43 AM
mxmikie Offline
Re: Sometimes my GENII SR wont start, have no idea what it could be...can't trust it. [Re: mxmikie] #1031148 07/06/11 05:41 AM
ryany Offline
Neither of those hoses is rated for submerged applications.
95 Montero SR
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6395 MB (Peak: 0.7479 MB) Data Comp: Off Server Time: 2026-06-20 20:17:18 UTC
