Re: OBX Racing Differentials in a '97 Sporty?!?
[Re: logansportage]
#1031437
07/23/11 03:30 PM
I'm hopping my boy will buy it, he's in the S & R also.
Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
[Re: DennisThompson]
#1031438
07/25/11 08:15 PM
The price is always right for a family member. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: logansportage]
#1031439
07/27/11 10:59 AM
Dennis,
If the front and rear are the same size, then I'm going to start looking for a 97 or newer that as the LS in the rear and maybe I can get a traction aid in the front. That or go with the OBX if it will fit in the front. The gear lockers would be the better way to go long term anyway.
Don't sell the KIA!!! Search and Rescue needs it.
Logansportage, Have a look at this thread reference front traction (locker) http://www.4x4wire.com/forums/showf...&an=0&page=0#Post1249137Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
[Re: 4runnernomore]
#1031440
07/30/11 02:03 PM
Is this for real? LSD Or this
2002 4dr Kia Sportage 4X4 Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
[Re: 2002_Sporty]
#1031441
07/30/11 04:24 PM
I've seen the Eaton diffs for sale on a few websites. But I don't think all of them actually have the item in-stock. If you wanted to go that route, I would contact the company to verify they actually have the item, being that they seem scarce nowadays. There is a seller on eBay that has a current listing. But for a few bucks over the price of one of the Eaton clutch-type diffs, you could have two of the OBX diffs (assuming they prove off-road-worthy). I hope to have that question answered within the next week... or two... or three... <img src="/forums/images/graemlins/shiner.gif" alt="" />
[Re: Peabody]
#1031442
07/30/11 09:18 PM
I just realized that the seller on eBay is the same seller as the "Just Differentials" posted above. Looks like that seller has 3 in-stock at the moment...
[Re: Peabody]
#1031443
08/05/11 01:03 PM
Jeff Harvey jeff@justdifferentials.com"Please review the attached estimate. Feel free to contact us if you have any questions. I have this unit in stock on my shelf at my location!  Please let me know if you would like to pull the trigger on this unit. Please include your full shipping address. Thanks. We look forward to working with you. Sincerely, Jeff Harvey JT's Parts & Accessories 5980 Goodwin Rd Cashmere, WA 98815 www.justdifferentials.comJeff@justdifferentials.com509-888-AXLE (2953) ext. 111 866-399-7532 fax" EAT19536 98-07 KIA SPORTAGE 10 BOLT EATON POSI 28 SPL $599.00 But: I want the Lock Right Locker for my rear. So go ahead and get it if you need it.
[Re: 2002_Sporty]
#1031444
08/09/11 08:49 PM
I wonder if Jeff has the rebuild kit for the 98-02 Eaton diff. I already have this one in the rear of my Sportage, and would like a traction aid in the front. Either the OBX gear locker, or a 97 or older real LSD would be great.
[Re: logansportage]
#1031445
08/10/11 12:08 AM
I had one of these OBX diffs when they first came out. It was on my turboed acura integra. It worked good. I took out the bolts and restacked the washers they had put in incorectly. Put the bolts back in with locktite and it was good to go. Another issue that may have been fixed by now was that the hole that the driveshaft went into was not chamfered on the inside. so it was easy to put shaft in but would not come back out without damage to the driveshaft. This was because the spring clips at the end off the shaft got caught on the non chamfered end. I may get these for my sportage front and rear. A lot off things to check before using it but it never broke once it was in. It's in my brothers car now. Just for reference I was pushing 30+ lbs of boost with a 1.8L 4cyl. on street tires. Not sure how much pressure that puts on the OBX.
96 Sportage EX. Automatic. Sold and sadly missed 4" UpYourKia lift
89 Ram 50 4x4. 4D56T swap in progress 30x9.5x15 Pirelli Scorpion M/T on Toyota steel wheels
06 VW Touareg V10 TDI.
[Re: hambodian]
#1031446
08/10/11 06:13 AM
Still no update on the OBX diffs. But I did jack up the Sporty and figured out that the drivelines rotate counter-clockwise to drive the vehicle forward. Why is that important??? Because I need to make sure the helical gears are properly-oriented in the OBX diffs for both the front and rear axles so they will transfer torque during acceleration, as opposed to deceleration. I'll post the details on all of that, once I have it sorted out. On another note, I did find the time to do a tune-up over the weekend - new Bosch Platinum+4 plugs, wires and coils, fuel filter, PCV valve, cleaned the throttle body... even installed a Spectre cone air filter (came with the vehicle, but had been removed to pass CA smog). My Sporty is running smoooooooooth!!! <img src="/forums/images/graemlins/smile.gif" alt="" /> And here's a pic of the "beast"... ![[Linked Image]](http://i999.photobucket.com/albums/af117/peabody1986/Sportage/tinytitan.jpg)
