Page 7 of 7 1 2 3 4 5 6 7
Re: OBX Racing Differentials in a '97 Sporty?!? [Re: Peabody] #1031477 02/09/12 10:55 AM
kia74 Offline
So what is happening did it work or not <img src="/forums/images/graemlins/confused.gif" alt="" />.I am gettin itchy <img src="/forums/images/graemlins/sleeping.gif" alt="" />
I love hammers
Re: OBX Racing Differentials in a '97 Sporty?!? [Re: kia74] #1031478 02/10/12 03:50 AM
Peabody Offline OP
Yes, the OBX diff works in the front axle of the Sportage. And that should hold true for all 4x4 Sportages made from 1995-2005 (they all have 26-sline x 27mm axles and 7" ring gears and use the same carrier and pinion bearings - only the rear diff changed starting in 1998, which was only a change in the axle and spider gears' spline count to 28-spline x 29mm; nothing else). As far as testing, I have only road tested it on paved streets. I haven't had a chance to hit a trail yet. However, it feels fine - no clunks or chunks or grinds. I am confident that it will be an improvement over the open-carrier that is stock equipment on the front end. For the price, it seems to be a very good solution... so far. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: OBX Racing Differentials in a '97 Sporty?!? [Re: Peabody] #1031479 06/12/12 01:47 AM
Peabody Offline OP
Update... I'm having an issue with the front drive. I'm getting a popping noise when I turn left in 4wd, which I can feel through the steering wheel. <img src="/forums/images/graemlins/scared.gif" alt="" /> I think everything is good with the front diff. But the front drive wasn't engaged. Unknown to me at the time, my Sporty will only engage the front drive when I shift into 4wd (high or low) with the tranny in neutral. "Shift on the go" or even stopped in "drive" doesn't do it. Going straight or turning to the right with the transfer case engaged works fine. I can feel the front tires gripping. So I know the OBX diff is working. But I'm going to have to do some investigating to figure out what's going on. More to come, once I have a chance to to dig into it... <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: OBX Racing Differentials in a '97 Sporty?!? [Re: Peabody] #1031480 10/22/12 06:31 AM
Peabody Offline OP
Finally... I have an update!!! I was able to pull my front axle and tear down the OBX diff. I found the cause of my trouble - the reason why the diff was catching and banging when I tried to turn left with the 4x4 engaged. The sloppy machining tolerances allowed one set of the helical gears (planetary) to contact the opposing axle gear ("sun" gear) when the vehicle was turning to the left. Straight was fine, as no gears move within the casing. And the right turn was fine because the gears didn't touch (barely...). Here's a pic of the gears that were catching, chipped teeth and all. <img src="/forums/images/graemlins/zombie.gif" alt="" />
It took a bit of thought, but I was able to come up with a fix: I took the gears to the bench grinder and beveled them so they can overlap without catching teeth. I tested the mod thoroughly to ensure the problem was solved. I did this by assembling the casing with all parts except the belleville washers, inserting a spline shaft in one of the sun gears and spinning the gears while holding the shaft upright with the diff on top (like a head on a pike... <img src="/forums/images/graemlins/evil.gif" alt="" />). The weight of the diff will push the sun gear up while the weight of the opposing planetary gears will pull them down. The lack of the spring washers allowed the "system" to act as if it were under sufficient load to overcome the preload of the washers, which is exactly what happens when the wheels turn at different speeds. If both gear-sets turn freely without hangups (have to test both sides this way), then the problem is gone. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Here's some pics of the modded gears...
And here's a pic of how the gears load into the case - the heavily-beveled ends all face toward the center, because that's where the overlap occurs...
Once I had it all sorted out, I reassembled the case and proceeded to install my new 5.38 R&P set (those details in another thread). Here's a tip for anyone that may decide to give the OBX diff a try - It's easier to torque the case bolts if you mount the diff in a vise like this (I torqued mine to 40 ft-lbs using red thread locker)...
Another issue I ran into while setting up the R&P was that the ring gear mount was out of "true" by about 0.004". That doesn't sound like much. But when the ring gear wobbles towards and away from the pinion, it can and will throw your backlash off. I found the simple way to fix it was to file the centerline-face of the diff case (ring gear side) to eliminate the high spot (the area that measures farther away from center). It took a few hours of filing (I used a diamond hone for sharpening blades), assembling the casing (no gears... no need) and loading the diff into the housing for measuring. But it worked! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Once that was sorted out, I did the final assembly on the diff and finished up the 5.38 R&P upgrade of my front axle (those details in another thread)...
I still have to put my fix-it-mods to the test. But I can't do that until I finish installing the 5.38 R&P set in my rear axle. I hope to get that done next weekend, time permitting. I am pretty sure the problem has been solved and the diff will function normally. That said, I want to table a few "insights". First, the direction of the sun gears may not make a difference after all. I say this because, after sorting out the issue with overlapping gears, I came to realize the following...
1) No gears turn when the wheels turn at the same speed (this isn't new and has been noted earlier in this thread).
2) Because the gears are not moving under the conditions of point (1), the pulling inward or pushing outward of the planetary gears against the case is a non-issue. It doesn't matter. (That's an epiphany)
3) When turning, one set of planetary gears will pull towards the center while the corresponding/meshed sun gear will move away from center. The opposing gear set will perform oppositely: the planetary gears will move away from center while the corresponding sun gear will move towards center. When you turn left, one set of gears shift to center. When you turn right, the other set of gears shift to center. This is a big epiphany!!! (For me, at least).
Thus, the direction of the sun gears, as mentioned earlier in this thread based on references from other OBX discussions on other forums, doesn't matter. This is due to the fact that the shifting of gears towards and away from center is dependent on variation in wheel speed (i.e. one wheel rolling faster than the other). And each gear set will move towards or away from center only when the wheel speed varies specifically (like turning right or left). The critical point of this is that the gear sets on one side turn in the opposite direction of the other side when wheel speed differs. And if the planetary gears from one side overlap the sun gear on the other side, the teeth of both will catch - catastrophically. This will happen because the planetary gears from one side and the sun gear from the other side BOTH MOVE TOWARDS THE CENTER under one specific turn condition (left or right). That's why bad things happen if the machining tolerances are crap... And that's what happened to me. Fortunately, the fix was relatively simple.
Taking all things into account, I am hesitant to recommend the OBX diff - assuming it works well off road. I say this because the quality of the product is low. It's a made-on-the-cheap-in-China product. The machining tolerances are sloppy and I had issues with the quality of the casting (case had pits, pockets and cracks). I was able to fix the issues (cracked case had to be exchanged - not an easy process). And the fixes, as I've noted, weren't too difficult, just tedious. For $279, a little elbow grease will give you a tough little diff. But the OBX diff is now selling for $358-$378 on eBay. That's another $100 over what I paid. And for that price, I'd shop for a quality-made diff that will drop in without hassle, even if it was a clutch-type LSD (or a Track Finder locker for the front). I will report back when I have had a chance to test the mods on the OBX diff, and assuming they work, how the OBX performs on the trail. Wish me luck...
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: OBX Racing Differentials in a '97 Sporty?!? [Re: Peabody] #1031481 10/22/12 10:01 PM
Peabody Offline OP
One more issue with the OBX diff that I forgot to note in my previous post... The shoulder of the ring gear mount on the OBX casing, where the ring gear should have a press-fit, was 0.002" smaller than the inside diameter of the ring gear. I tried mounting the gear to see if the ring gear bolts would self-center the ring gear. But it didn't happen. I then began to think of ways I could shim the ring gear against the case so it would center properly. I decided to work with a section of 20-gauge steel wire (solid) because I had it on-hand. Basically, I took a length of wire just shorter than the circumference of the diff case at the ring gear flange/mount and wrapped it around the base. Then I set the ring gear over it and tucked the wire into the chamfered edge of ring gear, which meets the corner of the flange and case. This bit of wire filled the gap between the corner and the flange. And when I bolted the ring gear down, the wire acted like a shim that was a crush-fit. It worked pretty well, bringing the measured runout down to 0.001". It isn't ideal. But it worked. And that bit of wire will not slip out of place - no way for it to move at all... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: OBX Racing Differentials in a '97 Sporty?!? [Re: Peabody] #1031482 10/29/12 05:55 AM
Peabody Offline OP
Update - I was able to finish installing the rear diff with 5.38 R&P. After giving the rear diff a run of testing, I found a gravel lot where I could test everything in 4wd. It works! So it appears the OBX diff is actually working without catching gears - no bad noises when turning hard in any direction!!! It actually seems smooth. And I did jump back and forth between 2wd and 4wd to make sure the front axle was actually engaging... <img src="/forums/images/graemlins/shiner.gif" alt="" /> So far, so good. I will post more after I have a chance to hit a trail...
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: OBX Racing Differentials in a '97 Sporty?!? [Re: Peabody] #1031483 10/30/12 04:27 AM
Peabody Offline OP
I took my Sporty back out for a bit of break-in driving. Richmond Gear recommends driving for 30 minutes at "normal driving speed", then letting the vehicle rest to let the gear oil cool down. This process is to be repeated for a total of 3 break-in runs. So I took the rig back to the gravel lot and gave it another go. I was able to turn hard left and right without issues. And the front wheels seem to be getting some good grip, though the Track Finder locker in the rear will overcome the steering a bit if I goose it a little too hard... <img src="/forums/images/graemlins/notooth.gif" alt="" /> That said, the OBX diff is working well and without any odd noises - it's running smooth. Now that I've tested it on a gravel lot, I have the utmost confidence that it will work well enough to get me out of the McDonald's drive-thru, should I ever have the need to crawl my way out. <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6448 MB (Peak: 0.7493 MB) Data Comp: Off Server Time: 2026-06-23 13:08:32 UTC
