Re: awe jeeze!! not this guy again. [Re: cmonty72] #1031689 07/16/11 02:16 AM
0778drz110 Offline
Rack a pinion steering... <img src="/forums/images/graemlins/lol.gif" alt="" /> I guess he was too lazy to make the idler arm IFS steering stuff work.
Re: awe jeeze!! not this guy again. [Re: 0778drz110] #1031690 07/16/11 07:28 PM
If anything could rack (///\\\\) a pinion, that thing could....
Re: awe jeeze!! not this guy again. [Re: fasteddy] #1031691 07/20/11 07:56 PM
RichinROA Offline
mmmm...rack and peanut steering.
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: awe jeeze!! not this guy again. [Re: RichinROA] #1031692 07/21/11 01:25 AM
Lloyd Swartz Offline
Rack and Pinon is a nightmare on a truck, can you emagine with those tires? That makes no sense.
Re: awe jeeze!! not this guy again. [Re: Lloyd Swartz] #1031693 07/21/11 02:03 AM
A friend has a mud buggy with r&p steering. The rack and steering box were mounted to the axle, with a pair of proper velocity sensing hydraulic steering dampers on the tie rod ends. It almost eliminated bump steer, but he had to have a special splined telescoping steering column fabbed. The part of the bump steer you cant get rid of is the part when the axle twists over extreme single wheel articulation. That part is there whether the box is on the frame or the axle, but the steering gear ratio multiplies the effect when axle mounted. It does get rid of the bump steer caused by simple vertical movement of the axle which usually puts toe out on the wheels as you jounce down, and toe in as you rebound.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6149 MB (Peak: 0.6792 MB) Data Comp: Off Server Time: 2026-06-07 03:21:30 UTC
