93 SR - Transmission Harness Question #1032298 07/29/11 03:32 AM
tdf46 Offline OP
Had my truck disassembled for a while. Now that it is going back together I cannot find the location to where to plug one wire harness connector on the transmission. It is a square 4 wire connector that is color coded (inside) purple. Any ideas? Anyone have a wire diagram for that harness?
Thanks
Wire - Not Part of Transmission ? [Re: tdf46] #1032299 08/01/11 03:09 AM
tdf46 Offline OP
Looking back at what few pictures I took and studying the area around the transmission, I've decided this part of the wire harness is not associated with the transmission. Don't no what it connects to at this point. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Wire - Not Part of Transmission ? [Re: tdf46] #1032300 08/01/11 03:39 AM
Shifter position indicator? Think the sender is on the shifter shaft on the pside of the tranny. I think the only other tranny possibilites (this is not the 'lectron shift model, right?) are the reverse light, and the 4wd and lorange light switches on the tcase. Wait, there's a pulse generator on the back side of the front output shaft on the tcase dside rear, too, and the tranny has the o/d electrovalve.
Re: Wire - Not Part of Transmission ? [Re: fasteddy] #1032301 08/01/11 04:23 AM
SRTNate Offline
Possibly the rear O2 Sensor? I know on the 95SR the O2 sensors are part of the transmission harness at one point. Here is the 95SR pinout at the junction between the dash harness and the transmission harness...I don't know how it compares to a 93.
Sorry if it's a bit jumbled, I'm still trying to find a good way to post/convert an Excell file.
Connector C-40-3 Dash to Transmission Harness
Pin 1 Yellow/Blue Center Differential Lock Operation Detection Switch
Pin 2 Blue/Orange 4wd Operation Detection Switch
Pin 3 Yellow/White 2wd/4wd Detection Switch
Pin 4 Yellow/Blue 4wd High/Low Detection Switch
Pin 5 Blue/White Center Differential Lock Detection Switch
Pin 6 Park/Neutral Position Switch (Reverse)
Pin 7 White Front O2 Sensor
Pin 8 Black Front O2 Sensor
Pin 9 Black/Red Front & Rear O2 Sensor Shield
Pin 10 Start/SRS Airbag System
Pin 11 A/T Fluid Temperature Sensor
Pin 12 Lock-Up Solenoid
Pin 13 Shift Solenoid #2
Pin 14 Shift Solenoid #1
Pin 15 Pulse Generator
Pin 16 Pulse Generator
Pin 17
Pin 18 Red Rear O2 Sensor
Pin 19 Green Rear O2 Sensor
Pin 20 Brown 0.85 Front O2 Sensor Heater
Pin 21 Black/Red 0.85 Front O2 Sensor Heater
Pin 22
Pin 23
Pin 24
Pin 25 Park/Neutral Position Switch (Low)
Pin 26 Park/Neutral Position Switch (2nd)
Pin 27 Park/Neutral Position Switch (Drive)
Pin 28 Park/Neutral Position Switch (Neutral)
Pin 29 Park/Neutral Position Switch (Park)
Pin 30
Pin 31 Park/Neutral Position Switch
Pin 32 Park/Neutral Position Switch
1989 Mitsubishi Montero SWB 0.0L (3.5L soon?) Auto, Front LSD, Rear SR Locker, Aisin hubs, Safari Snorkel, ARB Front Bumper, Warn M8000, Bushwacker Flares
1984 Mitsubishi Montero
2005 Dodge SRT-4
1970 Plymouth 'Cuda (in pieces)
...and a few others less interesting.
Figured It Out [Re: fasteddy] #1032302 08/02/11 12:42 PM
tdf46 Offline OP
I have had this truck all disassembled for 2 years. Enough time for memories of the disassembly to be erased from this old mind. I'm used to the O2 Sensor wires coming down from the engine bay NOT down through the cabin floor....haha. Man!!! Had me chasing my tail for a long while!
Lesson Learned: More NOTES and more PICS!
You are Correct [Re: SRTNate] #1032303 08/02/11 12:50 PM
tdf46 Offline OP
You are right on with the O2 Sensor SRTNate. Didn't see your post before my last reply. Bundling the O2 wire with the transmission harness really confused me. Figured it out when I started install of the exhaust and saw the sensor location. Thanks!! I'll save your PIN OUT data for later use.
Re: You are Correct [Re: tdf46] #1032304 08/02/11 02:55 PM
W
willwinchforfood Offline
Nate has a ton of pinout info for the 89 and 95 if you need more.
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6187 MB (Peak: 0.7110 MB) Data Comp: Off Server Time: 2026-06-22 08:32:27 UTC
