Page 6 of 6 1 2 3 4 5 6
Re: Its time for an SAS! Sloooooooow build. [Re: LandRaider] #1032436 02/15/14 03:58 AM
[quote]
I run 4.636 rear on my montero sport axle, and 4.56 on my D44 up front... No problems even on pavement.
Must be really rough there in AZ requiring 4WD on pavement. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Its time for an SAS! Sloooooooow build. [Re: Mudraider] #1032437 02/17/14 07:14 AM
LandRaider Offline
Well... I'm in south MS, but not much need for anything short of 1wd here on pavement.
Re: Its time for an SAS! Sloooooooow build. [Re: LandRaider] #1032438 02/18/14 06:53 AM
87monty Offline
Right on thanks, I was wondering but the gear ratio seems close enough not to effect anything to much.Hard dirt or pavement was my main concern.
Ok good! im getting it all the parts together I cant wait!
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Its time for an SAS! Sloooooooow build. [Re: 87monty] #1032439 02/20/14 12:50 AM
PA_JERO Offline OP
Ok, im bad about updates. So the axle is in, it steers and is movable on all 4 tires. I still need to work out the brake lines and master cylinder which is minor, probably wont do that until i have the motor and trans back in though. I am currently working on the engine, drop the heads off today at a machine shop to be checked and resurfaced. Should have rhem back in a week or so and then i can start assembling the motor, new timing stuff, gaskets, etc. All the usual crap. Since the original trans in the truck was a 4 cyl auto and i pulled to donate to a toasty project, i will put a late gen 1 auto with a lock up in to work with the 3.5. So i need to still get ahold of that , then its ready for the drive shafts and someother stuff. But its slowly getting there.
Re: Its time for an SAS! Sloooooooow build. [Re: PA_JERO] #1032440 02/20/14 01:11 AM
W
willwinchforfood Offline
Remember you need Gen 2 starter. I also think gen 2 other stuff in there. Find SrtNate's post
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Its time for an SAS! Sloooooooow build. [Re: willwinchforfood] #1032441 02/20/14 01:43 AM
PA_JERO Offline OP
I already finished the swap 4 years ago or so. I drove it around for about 2 years until i decided to do an sas and dual transfer cases. I figured with motor out it would be easier to sas it. Plus i needed to pull the motor so i could do valve stem seals and timing belt. So the motor swap is done. Just want a lock up trans behind it now too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 4.138s Queries: 16 (0.009s) Memory: 0.6198 MB (Peak: 0.7068 MB) Data Comp: Off Server Time: 2026-07-16 01:40:47 UTC
