Re: Timing belt kit [Re: 87Montero] #1033274 08/20/11 01:34 AM
justice Offline
FWIW some of the original (OEM) drive belts on the old 86 I had were labeled as "Mitsuboshi". I've noticed this on other OEM mitsu trucks too.
Re: Timing belt kit [Re: justice] #1033275 08/20/11 03:45 AM
Grasscat Offline OP
Yep, here you go.
Michael j
TreadLightly! Trainer
Timing belt kit [Re: Grasscat] #1033276 08/24/11 06:18 PM
Grasscat Offline OP
It's pay day so I order a few thing for the timing belt change from Rock Auto for the Cat.
Upon inspection, while changing oil, I found the boots to be in need of replacement also. So while replacing them I will upgrade to 4.6x gears. I have the front and rear diff's ready to go in.
Michael j
Re: Timing belt kit [Re: Grasscat] #1033277 09/14/11 01:44 AM
Grasscat Offline OP
It only took me four days to do this little job <img src="/forums/images/graemlins/zombie.gif" alt="" />, but the cat is purring like a kitten. <img src="/forums/images/graemlins/smile.gif" alt="" />
Everything had to be cleaned and spotless and the rubber seals had to be replaced on the plastic covers and .........
My hands look like I've been a cat fight and lost. <img src="/forums/images/graemlins/scared.gif" alt="" />
Michael j
Re: Timing belt kit [Re: Grasscat] #1033278 09/14/11 03:32 AM
RECON45 Offline
i remember the tore up hands when doing mine. the funny thing is i do not know how half of them got there. i think my job took about 4 days all together over the course of 1.5 months. glad yours is done and running well for you.
Re: Timing belt kit [Re: Grasscat] #1033279 11/15/11 11:07 PM
Clem1 Offline
Hi Grasscat,
I'm getting ready to do this job. I priced the parts at the two Mitsubishi dealers closest to me and just the parts in the Gates timing belt kit are over $600, so I'm going to go the route you did with Rockauto.
A couple questions:
The Fel-Pro cam seal part no. TCS45704 appears to have two front seals in it. Is that the case or do I need to buy two?
When replacing the rocker cover gaskets is it necessary to remove the intake/plenum or was changing the intake and plenum gaskets a preventative measure?
Fel-Pro vs. Victor Reinz, is one better quality than the other?
Thanks for your advice,
Clem
1999 Mitsubishi Montero (Winter Package)
Re: Timing belt kit [Re: Clem1] #1033280 11/16/11 05:41 PM
Grasscat Offline OP
Hi Grasscat,
A couple questions:
There are two in the package.
You need to remove the intake plenum. There's no way to remove the cover if you don't.
I don't know. Your guess is as good as mine. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
Re: Timing belt kit [Re: Grasscat] #1033281 11/16/11 07:19 PM
Happy Birthday hazy_daze Offline
Either will be sufficient. I've never seen any real quality differences between the 2 manufacturers.
Re: Timing belt kit [Re: Grasscat] #1033282 11/16/11 10:33 PM
Clem1 Offline
Grasscat & Hazy Daze,
I guess I'll go with the least expensive option, since there are no known issues with quality.
Thank you both for replying to my questions.
Clem
Re: Timing belt kit [Re: Clem1] #1033283 11/17/11 03:09 AM
Va_Stumpy Offline
Fix it....drive it.... post it. We are eager for results. I bored my 3.0 .040....Rebuilt it w/ the most economical parts available & am still going strong after 10,000 miles.
Mitsu makes a good product with a strong will to live!
Fix it & drive it like you stole it !!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6424 MB (Peak: 0.7518 MB) Data Comp: Off Server Time: 2026-06-23 11:34:46 UTC
