Page 1 of 4 1 2 3 4
Engine does not start! please help! #1033804 09/04/11 10:43 PM
cap510 Offline OP
Hey Guys, I'm in need of your help, yesterday I went to my local OHV park and at the end of the day I decided to give a mud hole one last run, I came down pretty hard and the engine just die. Mud/water went over the whole engine bay and now the engine wont start.
The engine turns but sound like there is no combustion or spark. I'm thinking something electric but can't pin point!
I can keep the starter going but it just turns and turns.
Any suggestion will be greatly appreciated!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: Engine does not start! please help! [Re: cap510] #1033805 09/05/11 01:14 AM
Mud in the optical trigger??
Open circuit in the coil packs?
Re: Engine does not start! please help! [Re: cap510] #1033806 09/05/11 03:58 AM
MarkG Offline
... I came down pretty hard and the engine just die.
It's possible that a wire came loose or a connector came apart.
Have you checked for any codes from the ECU?
Re: Engine does not start! please help! [Re: MarkG] #1033807 09/05/11 04:31 AM
1. Did you try any of the things i suggested?
2. I thought you were going to post a video or sound of the engine cranking
3. Did you pre order your copy of the new Anthrax CD?
Re: Engine does not start! please help! [Re: TOASTY] #1033808 09/05/11 05:14 PM
cap510 Offline OP
Yeah, I checked all electrical connection and everything looks good.
I replace the part that sits above the air intake where all the connectors go to and nothing happens still.
I read on other forums that when u crank shaft sensor goes bad engine will turn but won't start, do u guys think that might be the problem here?
Re: Engine does not start! please help! [Re: cap510] #1033809 09/05/11 05:53 PM
Chief Offline
Carlos,
It's simple,
Fuel, air, compression, spark.
Narrow down which of those you have, or have not, before you start replacing parts randomly.
'89 Raider V6, AT, SAS'ed, Dana 44 front & rear, 5:38 gears, NP 231 T-case.
'97 Montero SR, cold weather package, 4.90 R&P, BATTLEZ suspension w/ 2" lift, JAOS grill guard & under body protection, custom rock sliders.
Re: Engine does not start! please help! [Re: Chief] #1033810 09/09/11 07:45 AM
cap510 Offline OP
So I got spark coming out of all 3 coils, I got gas too... running out of ideas why it wont start! <img src="/forums/images/graemlins/confused.gif" alt="" />
Can any one confirm if the crank shaft was defective would it still start? <img src="/forums/images/graemlins/confused.gif" alt="" />
Riding on 37" MTRs
Re: Engine does not start! please help! [Re: cap510] #1033811 09/09/11 10:04 AM
P
pcc Offline
Spark at plug should be bright and blue. How do you know you're getting fuel - wet plugs? Not only spark, fuel, air, compression, but timing also.
Re: Engine does not start! please help! [Re: pcc] #1033812 09/09/11 01:33 PM
mxmikie Offline
timing belt
Re: Engine does not start! please help! [Re: mxmikie] #1033813 09/09/11 07:27 PM
timing belt
Wouldn't a broken timing belt break other things if he tries to start it and it turns the engine? <img src="/forums/images/graemlins/confused.gif" alt="" />
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6408 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-06-07 01:51:33 UTC
