Power Supply
#1034730
09/20/11 11:44 PM
I'd like to take a standard AC-DC computer power supply and convert it to be a DC-DC unit for use in the Raider without having to use a DC-AC inverter.
It seems that if the power supply converts 120 to 12, then 12 down to 5 and 3.3, then I should be able to just supply 12 and it would convert down.
Too simple?
Thanks
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
Re: Power Supply
[Re: WagonMaster]
#1034731
09/21/11 12:15 AM
In theory it could work. depends on the design of the circuitry. You'll need the schematic along with the component specifications to understand/figure out how it was designed. <img src="/forums/images/graemlins/kewl.gif" alt="" />
What are you making that requires 5 & 3 volts DC? A carputer?
Re: Power Supply
[Re: off-roader]
#1034732
09/21/11 12:38 AM
Yes, and DC-DC power supplies are under-powered and too expensive (much like a Lotus).
Re: Power Supply
[Re: WagonMaster]
#1034733
09/21/11 12:51 AM
It will work, I have used one in my Offroad trailer to power lights and 12V fans, works great. I used a 500 Watt for my applacation because it has more 12V outputs which I needed.
2003 limited 20 year anniversary 96 SR 87 Montero SWB=Turbo diesel 4BT T19 4sd with 205 transfer case
Re: Power Supply
[Re: WagonMaster]
#1034734
09/21/11 12:55 AM
How much power do the standard AC-DC power supplies in the computers require?
IIRC, there are many who have done similar things but on other forums. Guys, wasn't there a website like MP3.com or something similar that had a forum where you could discuss this in more detail with folks who focus on it? I recall they were doing things like using custom OS interfaces & modified touchscreens in custom cases/physical installs to make their car-puter easier to use.
Alternatively you may be able to get by with using a inexpensive 12vDC to 110vAC power converter. Yes I know it's pretty inefficient going from 12v DC to 110v AC back down to 5/3v DC but it may ultimately be simpler and easier to support versus using a modified power supply that if it goes bad isn't necessarily as simple to fix/replace.
I went through a similar exercise with my netbook. I spend a few days looking for a 12vDC to 19.5vDC converter with sufficient current ratings to support my netbook. Ended up being more expensive to buy than a $50 12vDC to 110vAC power converter that fits nicely under my passenger seat and can easily be replaced should it fail (one already has after ~ a year of use).
I don't mean to discourage you but do want to offer other ways to make it happen in case the modified power supply idea falls through.
Either way, I look forward to seeing the results.
HTH. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Power Supply
[Re: 87monty]
#1034735
09/21/11 01:08 AM
It will work, I have used one in my Offroad trailer to power lights and 12V fans, works great. I used a 500 Watt for my applacation because it has more 12V outputs which I needed. Would you be a dear and do a write-up? <img src="/forums/images/graemlins/cheers.gif" alt="" /> Thanks
Re: Power Supply
[Re: off-roader]
#1034736
09/21/11 01:10 AM
HTH. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I've checked the MP3car sight, and they seem to be pushing the DC-DC units (which they sell). I may end up with an inverter, but would like to avoid that extra step if I can.
Re: Power Supply
[Re: WagonMaster]
#1034737
09/21/11 01:57 AM
Thanks
Dear? WTH is that?
Michael j
TreadLightly! Trainer
Re: Power Supply
[Re: Grasscat]
#1034738
09/21/11 02:19 AM
Thanks
Dear? WTH is that? A dear is something a REAL Grasscat would hunt down and eat. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: Power Supply
[Re: WagonMaster]
#1034739
09/21/11 04:46 AM
If you had a deer and decided that it no longer needed sight, what would you then have?
