Brake Master Cylinder Suggestions
#1036473
10/20/11 08:40 PM
We are running Dana 60s, front and rear. The front is a kingpin 60 with discs from about '90 ish. The rear is a drum 60 from about 79-80.
What would people suggest that we run for a brake master cylinder. We are assuming that it has a stock YJ master currewntly. ___________________________________________
Re: Brake Master Cylinder Suggestions
[Re: Jim_Paget]
#1036474
10/20/11 11:55 PM
http://www.vancopbs.com/There are a couple of forum threads about brakes. However, VANCO does have a bigger master cylinder that has been used to solve braking issues.
[Re: 4x4Wire]
#1036475
10/26/11 01:18 PM
I personaly run a 72 Vette master and tossed all proportioning...it works because of caliper systems. 14 Bolts front and rear 10.5" ring gear former full float. 14" rotors with 4 piston wilwood fronts, but little ford explorer style brakes rear. Most times when I'm building jeeps w 1 tons, I use the oem master and never have problems. It's only when asked to upgrade that I look at 97 dodge 2500 master or Vette.
I'd run the stocker if it's ok and has not been left empty/dry.
SD
[Re: superdawg]
#1036476
10/27/11 01:41 AM
We ended up going with a master out of a '79 E350. It works really well.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6003 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-07 05:09:43 UTCValid HTML 5 and Valid CSS
