what did you do with your dodge this weekk end? #1036591 10/22/11 05:18 AM
motero Offline OP
I rotated the tires, changed the oil and the fuel filter. Now I have to get air bags or remove the leveling kit.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: what did you do with your dodge this weekk end? [Re: motero] #1036592 10/22/11 06:10 AM
4x4Wire Offline
And now for my next expense..... <img src="/forums/images/graemlins/lol.gif" alt="" />
Sounds like more work than I wan to do this weekend....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: what did you do with your dodge this weekk end? [Re: 4x4Wire] #1036593 11/06/11 04:48 AM
motero Offline OP
This week end I removed the front spring spacers. Next is the ball joints, swap the transfer case, advance the timing, adjust the valves.......then I might address the lack of paint but you don't really need paint in AZ.
01 montero limited
Re: what did you do with your dodge this weekk end? [Re: motero] #1036594 12/04/11 07:49 PM
4x4Wire Offline
What version of Dodge???
And, why transfer case swap??
John Stewart
Editor - 4x4Voice
Re: what did you do with your dodge this weekk end? [Re: 4x4Wire] #1036595 12/08/11 06:31 AM
motero Offline OP
It is a 95, 3/4ton, regular cab, long bed, Cummins, 5sp.
The transfer case has a bent shift fork causing the mode ring to get chewed up. I have a spare that has been freshened up to swap in.
01 montero limited
Re: what did you do with your dodge this weekk end? [Re: motero] #1036596 08/12/12 06:57 AM
motero Offline OP
I sold the 95 cummins and bought a 03 cummins. After lots of work on the new truck, I miss the old one. The old one drove like a tractor but was very reliable. So far the new truck has had, starter, water pump, ball joints, u-joints, clutch, steering upgrades, shocks, and Injectors. Now that it has been caught up on its health I hope to enjoy it for a long time.
01 montero limited
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6094 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-10-30 09:31:27 UTC
