Is resonator in exhaust system necessary? #1037381 11/05/11 05:55 PM
tengopajero Offline OP
hi all.
For the 3rd time in 14 months the exhaust pipe on my 1991 SWB Paj broke between the resonator and the muffler. my shop suggests that they could insert a straight pipe between the exhaust manifold and the muffler - which is still good as it's only 2 years old. i can't even find a resonator looking online. Is the resonator necessary to the system (if it were removed would turbo operation be affected for instance) and if it isn't what noise changes could i expect if it were removed?.
your comments and experience reports are welcome.
thanks
John
Re: Is resonator in exhaust system necessary? [Re: tengopajero] #1037382 11/09/11 04:44 AM
I had some stock mufflers and resonators removed from my 1968 Buick GS400, installed some turbo mufflers. Car ran better and went from 6 to 7 mpg. I don't think the resonator would do much, except to keep exhaust resonance attenuated.
Re: Is resonator in exhaust system necessary? [Re: rxinhed] #1037383 11/11/11 12:28 AM
JeffatTireBalls Offline
I run my 4D56 straight through 2.5" exhaust, no muffler or resonator. Sounds great and runs even better!
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
Re: Is resonator in exhaust system necessary? [Re: tengopajero] #1037384 11/12/11 06:56 AM
redbull Offline
It will run fine, possibly better and cooler. You may or may not like the new sound. That's the biggest risk, is hating the new sound.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6019 MB (Peak: 0.6579 MB) Data Comp: Off Server Time: 2026-10-22 12:12:11 UTC
