Wing Windows #1037987 11/16/11 01:52 AM
MadMax Offline OP
Ok guys I tired doing a search first but there was error, I decided to post a new topic. My rubber looks good and my felt does as well, however my wing widows whistle going 35-mph and up. Whenever I push in on the lock the noise stops or is at least livable, is there any remedies to sooth the roaring wind lol? Anyone ever replace the lock and if so it is hard to do?
Proud owner or driver of a 1989 Mitsubishi Mighty Max 4X4, 1989 Mitsubishi Montero SWB, 2008 Mitsubishi Endeavor, 2008 Mitsubishi Eclipse SE, 2007 Galant.
Re: Wing Windows [Re: MadMax] #1037988 11/16/11 02:15 AM
StockRaider Offline
caulking gun or epoxy to seal the windows work, although that makes the windows permanently shut... I do believe you can buy replacement rubber still. I would check auto glass places.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Wing Windows [Re: StockRaider] #1037989 11/16/11 02:35 AM
I have fixed it several ways. One, I took the handle out of the lock and jbwelded the hole shut, then drilled it back out to the right diameter and reinstalled the handle. Two, I just took out some lock handle/latch plate slop with an assortment of shims in various places, all obvious. Third, and perhaps easiest, self stick door weatherstrip, the flat sided rubber tube stuff, in your choice of white or tan and maybe black, Home Depot has it by the roll. Miter cut the corners for a good seal there.
Re: Wing Windows [Re: fasteddy] #1037990 11/16/11 02:29 PM
SledgeHammer Offline
how to fix the Alabama way.
Just cut it long enought o wedge it in there real good and it will stay put even over the bumpiest roads.
1991 Montero RS
Re: Wing Windows [Re: MadMax] #1037991 11/16/11 03:31 PM
monte3 Offline
They sell a security lock device that you tighten with a round knob to prevent theft.
This will also quiet the noise.
Sorry, but I can't recall where I purchased them. <img src="/forums/images/graemlins/confused.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Wing Windows [Re: SledgeHammer] #1037992 11/16/11 03:50 PM
dadrab Offline
Obviously, the slop comes from wear on the latch. I shimmed it to tighten. Cut several at one time (about 5mm thick) from the end of a 2x2.
Sort of a pain to open the window for a cigarette, but other than that, it works fine.
with awesome audio.
Re: Wing Windows [Re: dadrab] #1037993 11/16/11 05:59 PM
Use a penny between the latch and the window frame. Open the window, penny drops to floor, find another penny to use when you re-close the window.
Re: Wing Windows [Re: JohnnyBfromPeoria] #1037994 11/16/11 07:12 PM
heathdogg Offline
I use to use cardboard. I've given up cause my weatherstriping is so old, the wind just rips right it at highway speeds. I like cardboard cause it's free compared to a penny. That's alot of money now! <img src="/forums/images/graemlins/lol.gif" alt="" />
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Wing Windows [Re: SledgeHammer] #1037995 11/17/11 03:13 AM
Va_Stumpy Offline
i like the way you think.....I just keep bumping mine w/ my fist until it stops whistling. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Wing Windows [Re: Va_Stumpy] #1037996 11/17/11 03:50 AM
KrzyDav Offline
my passeger side screams when locked. The drivers side rubber that my dog chewed up works like new. I'm gonna put peanut butter on passenger side so he chews that one to quite it down <img src="/forums/images/graemlins/lol.gif" alt="" />
dave h.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6394 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-07-17 05:00:43 UTC
