Re: Wing Windows
[Re: MadMax]
#1037997
11/17/11 04:45 AM
I had a leaky sunroof seal. I cured it be spreading a thin bead of clear silicone over the entire seal, then let cure. Until I crashed that truck, it didn't leak again.
Re: Wing Windows
[Re: KrzyDav]
#1037998
11/18/11 03:08 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> That is some funny stuff there.
Re: Wing Windows
[Re: MadMax]
#1037999
11/18/11 04:04 AM
Re: Wing Windows
[Re: MontyMcV]
#1038000
11/18/11 04:32 AM
Radio doesn't go that loud!! Time for ear plugs.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Wing Windows
[Re: JohnnyBfromPeoria]
#1038001
11/18/11 05:45 AM
Use a penny between the latch and the window frame. Open the window, penny drops to floor, find another penny to use when you re-close the window.
John B. This is the logical solution. The penny trick works everytime.
Spence 1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Wing Windows
[Re: spencevans]
#1038002
11/18/11 01:49 PM
John B. This is the logical solution. The penny trick works everytime. Think a previous owner got mad and bent my latch cause a nickel wouldn't get mine to tighten enough to stop the whistling <img src="/forums/images/graemlins/lol.gif" alt="" /> Even tried to switch latches but realized the assembly is bent where the latch goes on
1991 Montero RS
Re: Wing Windows
[Re: SledgeHammer]
#1038003
11/18/11 02:01 PM
I put a little grease on the seal lip to fix my window ...But I must say to that I never use my wing window at all .. And I would think it would be a mess for someone that uses their wing window ....
Re: Wing Windows
[Re: haztoys]
#1038004
11/18/11 06:31 PM
my Raiders wing windows work great, I use the wing to deflect air around the open door window, so I can still drive with the window open in mild to moderate rain past 40mph. I had to seal the Monteros windows with silicone because the drivers wing window is rusted, and the seals are shot.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
Re: Wing Windows
[Re: StockRaider]
#1038005
12/10/11 02:04 PM
Just fixed my wind wings .. <img src="/forums/images/graemlins/smile.gif" alt="" />...
(Not sure how to explain this here but ..)
As your sitting in the truck seat ... Look were the wing rubber meets the door window channel ... I got three rubber o-rings about three inches around with a small cross section .. Cut them then stuffed them in the crack between the wing rubber and the door window channel .. It pushed the wing rubber into the wing glass better and fixed the wind noise ...This may help others ..If you can under stand what I'm try to say ..LOL...
