rear coil spring wire diameter info
#1038177
11/19/11 04:28 AM
SWB OEM coils 14mm , out of vehicle ht. 16 1/2 " SR OEM " 16mm , " " " 15 1/2 " Old Man Emu#910 17.3 mm " " " 15 1/2"
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: rear coil spring wire diameter info
[Re: KrzyDav]
#1038178
11/22/11 05:05 PM
Thanks Dave <img src="/forums/images/graemlins/cheers.gif" alt="" />
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
[Re: WagonMaster]
#1038179
11/23/11 02:08 AM
after a couple weeks , I'm real happy with the SR springs. They are alot softer than the OME but way better than the OEM constant rate on this really windy "Hwy of Death" , HWY 41 I live on. They give me a little more clearance on my gas tank the builds up "a lift" of snow pack. Also better for towing lite loads. The OME would be good if I towed heavy loads all the time like Russell does. They were extreme overkill for my D.D. campmobile Raider.
PHP: 7.4.33 Page Time: 2.465s Queries: 15 (0.003s) Memory: 0.5953 MB (Peak: 0.6489 MB) Data Comp: Off Server Time: 2026-05-29 16:35:04 UTCValid HTML 5 and Valid CSS
