What is the best oil filter for Montero #1038300 11/22/11 02:27 AM
matseel Offline OP
Greetings!
I hope this finds everyone in good spirits. What is the best oil filter for 1994 Montero SR 3.5 liter? I've always used OEM, but considering K&N or Mobil 1.
I'm open for suggestions! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Happy Trails
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum,
OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2
New Mexico Land of Enchantment
Re: What is the best oil filter for Montero [Re: matseel] #1038301 11/22/11 03:07 AM
Va_Stumpy Offline
From what I've read...WIX or Amsoil filters are the best over the counter ones out there.I use WIX filters on my 3 rides & use fully synthetic oil. Change them every 5000 miles.
'02 Dodge Intrepid R/T 3.5L 120,000
'95 Silverado Z71 1500K 5.7L 225,000
'89 Raider 3.0 10,000 (since re-build..242,000 prior)
I'm sure others will chime in.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: What is the best oil filter for Montero [Re: Va_Stumpy] #1038302 11/22/11 09:52 AM
KrzyDav Offline
Wix = NAPA Gold,,,, <img src="/forums/images/graemlins/kewl.gif" alt="" />
dave h.
Re: What is the best oil filter for Montero [Re: matseel] #1038303 11/22/11 12:56 PM
P
pcc Offline
Re: What is the best oil filter for Montero [Re: pcc] #1038304 11/22/11 04:01 PM
Bob Is The Oil Guy
I use NAPA Gold.
Just don't use Fram.
Re: What is the best oil filter for Montero [Re: JohnnyBfromPeoria] #1038305 11/22/11 07:44 PM
Canyonero Offline
I use WIX as well.
and x2 on not using Fram.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: What is the best oil filter for Montero [Re: matseel] #1038306 11/22/11 09:50 PM
socal1200r Offline
If you change your oil every 5000 miles, it probably doesn't make a big difference what kind of oil filter you use. I would guess that the less expensive ones like Wix or Napa would be just as good as the more expensive ones like K&N, at least over the course of 5000 miles. From what I remember, at least on my 1984 Honda Ascot motorcycle, a K&N oil filter costs 2-3 times what a "regular" oil filter costs, and isn't worth it if you chang the oil and filter every 5K.
1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012)
Southeast VA, USA
Re: What is the best oil filter for Montero [Re: socal1200r] #1038307 11/23/11 01:11 AM
Angelo Offline
I use Royal Purple synthetic & oil filter. 201K on the clock, so far so good
Re: What is the best oil filter for Montero [Re: Angelo] #1038308 11/23/11 01:24 AM
8
89mitsuraider Offline
I use MOBIL 1 Extended Protection Full Synthetic, and a NAPA GOLD oil filter.
Keep On Rockin' In The Free World
88 Dodge Raider 2.6L 5spd, LSD, Bouncy seat
Re: What is the best oil filter for Montero [Re: 89mitsuraider] #1038309 11/24/11 01:46 AM
MadMax Offline
The Stock Denso oil filter (original to Mitsubishi's specs) would be my pick. You can even buy Mitsubishi oil, it's called eneos. However, I usually run Mobil 1 full syn. The stock filter costs no more than a wix/fram or any others.
Proud owner or driver of a 1989 Mitsubishi Mighty Max 4X4, 1989 Mitsubishi Montero SWB, 2008 Mitsubishi Endeavor, 2008 Mitsubishi Eclipse SE, 2007 Galant.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6397 MB (Peak: 0.7589 MB) Data Comp: Off Server Time: 2026-07-17 02:07:19 UTC
