Re: Upgrades
[Re: barak]
#1039289
03/08/12 12:00 AM
Well the weather wasn't too bad today so I installed my new gauges in my cluster , spliced into the parking light switch so they light up when the lights are on, there is a little switch that I can choose green or blue at night , as well as a built in dimmer.The needles were a little sticky at first , but I got them so they swing free now.
I also installed some LED lights in my dome lights (all 4) plus some in my front door lights.What a difference in brightness over stock.Of course i found you have to have the wiring placed in the proper way or no lights.It took me a minute to figure out why one light worked but the other didn't after I put them in.So I changed the way the wire went and voila , instant light:thumbsup:
Still have projects to do , but they are slowly getting there.Once my fog lights come in , possibly tomorrow , then I will install those , and the HID kits , making a couple less projects to do.I will try and get some pics later when it gets dark so everything is more noticeable.
Re: Upgrades
[Re: barak]
#1039290
03/08/12 03:04 AM
Re: Upgrades
[Re: barak]
#1039291
03/11/12 12:13 AM
It was a nice day out today so I took advantage of it and took off the exhaust manifolds , all the bolts came out nice and easy thanks to spraying pb blaster on them every time I was under the hood.I still have to take out the 4 studs in the center of the block , I think I might try some JB weld and a nut on there and hopefully that will let the studs walk out easy.Also with the manifolds off and the exhaust out of the way it gives me a lot of room to put in the control arms , so I might do that tomorrow if it is as nice as it was today.I also have to fab up a plate for the EGR tube on the headers as it did not come with a plate , only a gasket if you have EGR.I also installed my new fog light units and the HID for the fog lights , I will have to adjust them yet , but they look great.
Re: Upgrades
[Re: barak]
#1039292
03/11/12 11:47 PM
Today didn't go so well out there.I made a plate for the EGR on the headers that was easy enough , then I went out and got started on the control arms.I thought it would go quick and I could get most of the suspension done today , but of course easy things never go easy <img src="/forums/images/graemlins/scared.gif" alt="" /> I got 3 of the control arms off and replaced , not torqued yet but on with the bolts through ready to be torqued.I got to the driver side , the back bolt came undone easy enough , but do you think I could get the front one?I broke a ratchet , not the socket the actual ratchet , a 3/8 drive while I was using it and a cheater bar for leverage.When I heard the snap and everything let go , I thought I had snapped the socket.I picked up the pieces and here the ratchet head had snapped off <img src="/forums/images/graemlins/scared.gif" alt="" /> I believe there is a lifetime warranty on it so I will take it in and see if they will replace it.I can turn the nut or the bolt side , but both turn at once , so using back up on the opposite side , I tried again , no luck.So , I thought I would be smart , take off the tire and use my 1/2" impact gun.I tried for over an hour , alternating banging on it with a hammer , impact gun , more pb blaster , impact gun , not a thing moved , even with back up.
My next thought was I will try the dealer and see if I can replace that bolt and nut as it has to do with alignment , the bolt has a flat spot on it , and a plate on one end , the other side the plate comes off , then a nut.I can't really see any other way of getting this thing off seeing it snapped a ratchet and an impact gun has no effect.I will be on the road all week working so everything is on hold until I get back and have some more time.
Re: Upgrades
[Re: barak]
#1039293
03/17/12 11:29 PM
Today I went and picked up my $34 cam bolt from the dealer , a few rods for my welder , and replaced the ratchet that I broke trying to get that cam bolt out.Took a couple minutes with a grinder to cut that cam bolt out , put the new control arm and cam bolt in , but like the other control arms I have not torqued anything down just yet.I then welded the nuts onto the studs in the block , and with all the PB blaster I had sprayed on over the last weeks they came out pretty easy , no broken studs.
My harness for wiring in my LED so they turn on and off properly with the DRL came in so I wired that in as well as installed my HID kits on the headlights.I also adjusted my fog lights but until it is dark don't know if they are exactly where I want them to be.The project list is getting smaller and smaller now , everything is coming together very well.
I then started playing around with the headers , got the driver side and the flange loosely bolted up , just need to torque it all up on that side.The passenger side didn't go as well , because I didn't take out the oil filter , as everything came out fine with it on , I am 1/2" short for room to get the flange stuck down there.So , I guess tomorrow I am going to pick up a filter and some oil and will end up doing an oil change even though I don't need it.Once the filter is out the header should slide in there nicely.I noticed on the bolts that they gave me one shorter bolt for the flanges , and I am thinking the short one is used on the passenger side in that one corner.
Re: Upgrades
[Re: barak]
#1039294
03/19/12 12:01 AM
Today I drained the oil , took the filter off , and guess what, it made no difference for room to get the passenger side header on.I ended up using my stock jack to push the trans over a little and soon as I did that it plopped right down into place.I have everything bolted together loosely right now , just need to torque it all in.I went and cut the stock pipe a little too much , now I will have to get a short piece of pipe too connect to the collector and the stock pipe going into the cat.Once all that is torqued in , it's just a matter of finishing up with the suspension , which comes down to the ball joints , tie rod ends , track bar and steering damper.Then will have an alignment done and we should be all good.
Re: Upgrades
[Re: barak]
#1039295
03/19/12 11:58 PM
Got all the exhaust done and headers torqued in.After running it for 20 minutes I re torqued it but only one got a little bit re tightened , and of course I will check it again down the road.The only problem i found is where I had to fab up something when I cut the stock pipe too short , forgetting I had put the magnaflow cat in there so the dimensions were a little different.There is a small exhaust leak there , but I will just play around with it , try a couple different options out and I should be able to get it to be fine.The sound is a little different , but the idle is the same as stock.Until I finish the suspension I can't take it for a spin and see what the power difference is. Here are a couple pics of the engine bay , one of each side and one from the bottom. ![[Linked Image]](http://i2.photobucket.com/albums/y26/shadowbarak/IMG_3289.jpg) ![[Linked Image]](http://i2.photobucket.com/albums/y26/shadowbarak/IMG_3290.jpg) ![[Linked Image]](http://i2.photobucket.com/albums/y26/shadowbarak/IMG_3291.jpg) I also left the spark plug heat shields off , one reason is they are a pita to get back on , and they look stupid in there with the headers.I think it should be fine without them, as my last truck I built with headers I did not have the plug heat shields and everything was great for a couple of years until I sold the truck.
Re: Upgrades
[Re: barak]
#1039296
03/24/12 09:19 PM
Ran a little sea foam through the engine today , what a nice plume of smoke lol.The nice thing about it is the water is pushes through the exhaust was black , so I found 2 tiny little pin holes that you can't hear by ear.I will fix those up when it warms up a little and put some exhaust cement over it , then am all good.I did manage to get the LED lights working the way I want them too.I have it set so when the jeep is running the LED are on , I turn the jeep off they turn off in 7 seconds.If I turn on my headlights , the LED go off , turn off the lights they turn back on.All I can say is damn I am good lol. The wiring harness I got that was supposed to do this did not work , as soon as I plugged it onto the battery it had constant power , so it was defective , so it is going back.Just need some warm weather when the wind isn't howling and I can finish up my front end.
Re: Upgrades
[Re: barak]
#1039297
04/06/12 05:51 PM
Went out today for a few , was too cold to stay out there to long and is about to snow.Anyway I took some pics of everything apart with the knuckles painted black with tremclad , put the ball joints in on both sides and put the steering knuckles back on.I tried to press them back on but they only went on so far with a gap on top and bottom , but more pronounced on the top side.I can't remember if there was a gap there when I took everything apart , so hopefully someone looking at the pics can verify this or not.Maybe when they are torqued down it might suck them in a little more? ![[Linked Image]](http://i2.photobucket.com/albums/y26/shadowbarak/IMG_3297.jpg) This is the gap on the top ball joint where the knuckle sits. ![[Linked Image]](http://i2.photobucket.com/albums/y26/shadowbarak/IMG_3298.jpg) Here is the bottom one , the next pic is a close up of the bottom , but is a little blurry but the gap is noticed a little more. ![[Linked Image]](http://i2.photobucket.com/albums/y26/shadowbarak/IMG_3300.jpg) ![[Linked Image]](http://i2.photobucket.com/albums/y26/shadowbarak/IMG_3299.jpg) It is supposed to warm up for the weekend , so I will try and finish that up , finish putting the new steering links on , put everything back together and get it all torqued up then take it in for an alignment.
Re: Upgrades
[Re: barak]
#1039298
04/08/12 09:00 PM
