Check EGR #1039349 12/23/11 01:24 AM
8
87Raider Offline OP
Hello, does anyone have a clue what would cause the EGR light to come on? I just took it in two days ago and it passed smog with no problem. It runs the same as it did before the light came on, I replaced the O2 sensor because it thought that might be it since its running so good. I did notice the light on after I made a hard right turn, but I don't see how that had anything to do with it. The engine has 20k on it along with the EGR and Carb and all the thromo valves, temp sensors etc.... Thanks Mike
Re: Check EGR [Re: 87Raider] #1039350 12/23/11 01:30 AM
How many miles does the vehicle itself have on it? Did the light come on right at a certain even-numbered mileage interval?
Re: Check EGR [Re: JohnnyBfromPeoria] #1039351 12/23/11 01:44 AM
mxmikie Offline
pull the speedo out and flip the switch on the back
Re: Check EGR [Re: mxmikie] #1039352 12/23/11 01:57 AM
No need to pull the speedometer, just the little cover behind it.
Re: Check EGR [Re: rxinhed] #1039353 12/23/11 02:10 AM
8
87Raider Offline OP
Justed turned 180000, that's about when the light came on. So there's a switch on the back,, that has to be the strangest thing I ever heard of. Well I guess I just wasted 30 bucks <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Check EGR [Re: 87Raider] #1039354 12/23/11 03:02 AM
8
87Raider Offline OP
I pulled the cover off, can't see the back of the speedo, I guess I'll pull it out tomorrow. Thank you for all the info
Re: Check EGR [Re: 87Raider] #1039355 12/23/11 05:25 AM
The switch isn't on the back of the speedo, it's down at the base on the front. If flipping the little switch doesn't work to put the light out, or if you can't find the switch, just pull the bulb.
It was meant to be a reminder to check/service the system, namely to clean/inspect/replace the EGR valve. And it is pretty dumb.
Re: Check EGR [Re: JohnnyBfromPeoria] #1039356 12/23/11 05:27 AM
And replacing the o2 sensor isn't a bad idea, anyway. My bet is that your mileage will increase slightly.
Re: Check EGR [Re: JohnnyBfromPeoria] #1039357 12/30/11 10:10 PM
8
87Raider Offline OP
Flipped the switch, worked fine
PHP: 7.4.33 Page Time: 3.945s Queries: 15 (0.003s) Memory: 0.6267 MB (Peak: 0.7141 MB) Data Comp: Off Server Time: 2026-06-13 14:06:37 UTC
